Go Back   maXbimmer Forums > Classifieds > For Sale > Suspension & Brakes
Old 02-22-2012, 03:24 PM   #1
5ABIVT
Cheap reliable fast.Pick2
FS E46 M3 CSL / ZCP Rotors mint front/rear
Lightly used on the street no track use. Am going to go full brembos with their floaters so I don't need these .
These require csl or zcp option or if you want the bigger rotors up front and have a regular m3 all you need is front caliper brackets and these bolt right up.
These are well over $1100-1200 new for all four give or take depending on where you buy (slightly cheaper if you choose to smuggle over the border and want the risk).
$550 takes all 4. Pics coming soon.
5ABIVT is offline   Reply With Quote
Old 02-24-2012, 05:13 PM   #2
//Mik3
So i just need front caliper brackets and these will bolt up? Pm sent !
//Mik3 is offline   Reply With Quote
Old 02-24-2012, 06:50 PM   #3
E46coupe
E92 M3
E46coupe's Avatar
check your msg
Space Grey,Fox Red,DCT,EDC,Swift Springs,Carbon Fiber Roof,Diffuser,Splitters,Carbon Mirrors,M Performance Exhaust,ZCP Wheels,Caron Fiber Roof,15/12.5 spacers
E46coupe is offline   Reply With Quote
Old 03-07-2012, 10:11 PM   #4
gleech
gleech's Avatar
willing to separate. if so, I'll take the rear rotors.
gleech is offline   Reply With Quote
Old 03-10-2012, 07:48 PM   #5
5ABIVT
Prefer to sell as a set unless someone wants the fronts alone.
Old 03-10-2012, 07:53 PM   #6
Quickid
Interested in the whole set. Sent you PM with questions. I need to verify that these will fit my Z4 MCoupe. Do you happen to have part numbers?
Quickid is offline   Reply With Quote
Old 03-10-2012, 08:12 PM   #7
5ABIVT
Returning pms in a minute. These are the bigger front csl rotors as from what I know the euro models have 2 piece rotors but they are the std diameter up front. Rears are same csl/euro. I'll check if there are part numbers.
I bought these from an 05 zcp model that was in a rear end write off and he parted out. I'll get pics in a few. I spent like $50 on evapo-rust and dipped them all and wire brushed the light surface rust off so they look great just dark from the evapo-rust coating that stays on them. The car had 23k miles on it and owner said he never tracked. No cracks or anything.
Old 03-10-2012, 10:42 PM   #8
5ABIVT
Here's a pic of the one front I dipped in the solution. I haven't cleaned them or anything and just left them as is because the solution leaves an anti rust coating on (dark stuff).
Old 03-10-2012, 10:57 PM   #9
5ABIVT
Crappy cell pic here's a front and 2 rears.. Other front is in the bin soaking in the solution.
Old 03-11-2012, 12:21 PM   #10
5ABIVT
Here's a pic I found before I dipped it
Old 03-13-2012, 01:19 AM   #11
khurram
khurram's Avatar
pix of the weight left on them?
Silver 323CI *SOLD*
Silver E36 ///M *SOLD*
IB on CinnamonE46 ///M *SOLD*
Dakar Yellow E36 ///M *SOLD*
SG on LSB E46///M
khurram is offline   Reply With Quote
Old 03-13-2012, 01:51 AM   #12
5ABIVT
I'm assuming you mean thickness? Will get it I know there's lots of meat left just font remember the numbers .. 26 or 27 something ...
Old 03-13-2012, 02:12 AM   #13
5ABIVT
27.2 fronts (few very thin grooves just to bE anal read 27.0 ) 19.5 rears. Forgot to check the min thickness ..
Old 03-13-2012, 02:16 AM   #14
5ABIVT
Min Thickess is 26.4mm and 18.4 mm so tons of life !
New is 28 and 20mm f/r
Old 03-13-2012, 04:53 AM   #15
//Mik3
Pm sent!
