Old 02-15-2012, 08:57 PM   #1
Helka
BMW4LIFE
Helka's Avatar
Question K&N Install (Car running lean)
Hey Guys
So I have an Injen intake system and decided to replace the dirty filter with a k&n cone. After install car was running great but a few days of driving it led to my SES light to come on. Both Banks were running lean. The original filter measurements are 3.5 Flange inside diameter 5.5 base, 6.875 heght and 4.5 top. The K&N filter measurement is 3.5---8---8---6.625. So clearly much bigger filter.
My question is. Is it possible that the filter is too big and my mass air flow sensor cannot keep up with reading the amount of air that is being taken in thus running the car lean.
I know there is talk about the oil getting onto the mass air flow sensor, so i have cleaned it and still the codes come up. I did put the old filter back on and no codes came up so that cancelled out any vacuum leak after the MAF.
Jasper
CURRENT RIDE
07 BMW 328i
PREVIOUS RIDES
1994 BMW 318i
1993 SATURN SC1
1989 TOYOTA MR2 SUPERCHARGED
1975 BMW 2002
Helka is offline   Reply With Quote
Old 02-16-2012, 02:23 PM   #2
BMWdouche
Not Banned... Yet
BMWdouche's Avatar
What did you clean the MAF with - there is special MAF cleaner available.
BMWdouche is offline   Reply With Quote
Old 02-16-2012, 09:14 PM   #3
Helka
BMW4LIFE
Helka's Avatar
I used CRC Mass airflow cleaner
CURRENT RIDE
07 BMW 328i
PREVIOUS RIDES
1994 BMW 318i
1993 SATURN SC1
1975 BMW 2002
Old 02-16-2012, 09:22 PM   #4
StraightSix
StraightSix's Avatar
Your filter can be bigger than your whole car and it won't make a difference. Your engine will suck in as much air as it needs and your maf has no problem keeping up. Usually running lean is a sign of a bad MAF. Try cleaning it again? Maybe the MAF has permanent damage, but hopefully not.
Good luck!
StraightSix is offline   Reply With Quote
Old 02-17-2012, 04:43 AM   #5
Helka
BMW4LIFE
Helka's Avatar
I've been running with stock box for a few months and the MAF is fine. It only acts up when the K&N is in. I just put the injen intake back on and i'm going to see if i get a light on with the injen filter. I never did before only when i installed the k&n using the injen pipe.
CURRENT RIDE
07 BMW 328i
PREVIOUS RIDES
1994 BMW 318i
1993 SATURN SC1
1975 BMW 2002
Old 03-17-2012, 03:17 PM   #6
BimmerboyPH
BimmerboyPH's Avatar
Interesting. Is the k&n and oiled filter?
I installed a dinan intake which modifies the factory box and use's a k&n drop in filter which is oiled and i have never had a problem. Touch wood!
88 325is- written off
89 735i 5 spd- traded
89 325is m50 swap- sold
92 325is- sold
97 328is- sold
00 Land Rover Disco- sold
07 328i- sold
84 325e- track car, in progress........ SOLD!
87 325is- FOR SALE
98 328is- Current Daily
BimmerboyPH is offline   Reply With Quote
Old 03-20-2012, 08:25 AM   #7
Dinanstu
Get your injectors clean. Your injen intake is drawing more air (combined with filter) and the injectors aren't adding enough fuel.
Old 03-26-2012, 07:44 PM   #8
Helka
BMW4LIFE
Helka's Avatar
K&N is an oiled filter. I did run injector cleaner through but still it through codes.
CURRENT RIDE
07 BMW 328i
PREVIOUS RIDES
1994 BMW 318i
1993 SATURN SC1
1975 BMW 2002
Old 03-27-2012, 09:14 AM   #9
Dinanstu
It's not the filter. Every Tom Dick and Harry adds K&N filters without any problems. The exisiting software should be able to adjust for the air flow unless there is a problem with the oxygen sensors or the MAF itself.
I am assuming that it is the only change you have made to this car.
I would be curious what the A/F ratios are throughout the range with the stock system in place...
Sounds like you need access to a broad band oxygen sensor set up and to see what is actually going on...
Old 04-02-2012, 12:53 PM   #10
Helka
BMW4LIFE
Helka's Avatar
Other then the Injen intake I have a muffler delete but that shouldn't affect air into the system.
CURRENT RIDE
07 BMW 328i
PREVIOUS RIDES
1994 BMW 318i
1993 SATURN SC1
1975 BMW 2002
Old 04-02-2012, 01:34 PM   #11
Dinanstu
Increasing exhaust out, increases air in...
What CEL code are you pulling?
Old 04-02-2012, 03:33 PM   #12
Helka
BMW4LIFE
Helka's Avatar
i cant remember the codes but both banks are running lean. 0174?
CURRENT RIDE
07 BMW 328i
PREVIOUS RIDES
1994 BMW 318i
1993 SATURN SC1
1975 BMW 2002
Old 04-02-2012, 05:56 PM   #13
Dinanstu
What MAF is in the car? Perhaps a fellow member would be good enough to swap one out to see if the error persists.
Please check all connections to ensure there is no vacuum leaks.
Old 04-03-2012, 07:47 PM   #14
Helka
BMW4LIFE
Helka's Avatar
I've re-installed the injen intake and put back the amsoil filter and haven't had any issues. My MAF is running fine. i've also cleaned it a couple of times seeing if the oil from the filter may have caused the codes. I know I dont have any vacuum leaks or they would still be throwing codes. I might try and buy a smaller k&n filter then the one i had before and see if it throws codes.
CURRENT RIDE
07 BMW 328i
PREVIOUS RIDES
1994 BMW 318i
1993 SATURN SC1
1975 BMW 2002
