Old 02-17-2012, 12:17 AM   #1
Ryezee36
Something special
Exclamation Starting issues
So as stated in my last thread, my build came to a pause for starting issues. So before I pull the starter, is there any other problems that could prevent the car from turning over?
I find when I turn the key, I get a click from the starter, but it does not happen every time I turn the key, sometimes its silent, I have checked all the fuses and also replaced a couple noticed blown but nothing has changed in terms of it starting.
Any advice? Thanks!
Ryan.
Ryezee36 is offline   Reply With Quote
Old 02-17-2012, 12:43 AM   #2
95% sure its the starter. Just change it, its not a fuse issue....If you get a click but no start it means only two things; bad starter, or not enaugh power to the starter (bad battery, bad connection, etc).
Old 02-17-2012, 11:29 AM   #3
jon.e
jon.e's Avatar
Starter. had the same problem. Not too easy of a job.
E36 s52 powered 328i - track car
2002 Honda civic si veloz- DD
jon.e is offline   Reply With Quote
Old 02-17-2012, 12:15 PM   #4
Ryezee36
Something special
Yeah I already started taking things apart.. if you remove the top of the manifold and move the harness its not that hard to remove... on the m44 that is
