Old 01-23-2013, 01:02 PM   #1
civic_eater
civic_eater's Avatar
91 e34 obc ignition lock out? Reset?
So my friend just bought his first bmw a 91 e34. Car ran great and it had an ignition lock code set on the obc that was 0000. My buddy being a noob changed the code and then forgot it..... How do i reset this security system?now the car wont start without the right code
civic_eater is offline   Reply With Quote
Old 01-23-2013, 03:16 PM   #2
no clue....did you try to disconnect the battery overnight? will that even help?
Old 01-23-2013, 03:44 PM   #3
MANDD
Autobahn East
The 91 E34 uses OBC 4. To deactivate this in the event the code is forgotten do the following;
1. Disconnect and then reconnect the battery
2. Turn ignition to position 1 only. (the horn may/will sound)
3. The OBC will now display a time of 15:00 minutes, this will now count down.
4. After the 15:00 minutes has elapsed the car may be started.
Mark.
Old 01-23-2013, 07:33 PM   #4
civic_eater
Will it do that everytime or can i reset the code?
Old 01-23-2013, 08:30 PM   #5
TSI
Reverse Gear Member
You can reset the code. Once you start the engine the code is erased.
