Old 07-29-2012, 11:22 AM   #121
nate_s89
Unfortunately not. I had an opportunity to take a job at McLaren Performance so I am now living in Michigan and the car is back in Canada. I am moving back the end of August so there should be some big updates throughout September. Probably only get a month of driving it then off to the dyno to get some pre cryo tests done and then away it will go for treatment.
nate_s89 is offline   Reply With Quote
Old 09-05-2012, 10:28 PM   #122
adam325i
adam325i's Avatar
So, you back in Canada now??
90 325i 4dr Winter fun
90 325i 2dr Summer/track car
87 325i 4dr Parts
adam325i is offline   Reply With Quote
Old 09-06-2012, 09:28 AM   #123
SiR
Vtec just kicked in
oh damn I totally missed that. how did you score that?
very nice!
-||Old Crayons||-
Old 09-14-2012, 11:23 PM   #124
nate_s89
That I am, living in Ancaster. How is the project coming along?
very nice!
Somewhat of a cold call and applied, it was an amazing experience and I can't wait to go back. Not to mention how cheap gas and booze is in the states.
Cryo treatment looks like its going to happen January sometime, can't wait to start working on it again.
Old 09-16-2012, 08:29 PM   #125
adam325i
adam325i's Avatar
Im just finishing unbolting everything from the m54. then need to finish up some other projects and clean and re-orgainize the garage, save some $$ for parts. Would love to meet up with you in person and talk engines.
87 325i 4dr Parts
Old 10-21-2012, 11:25 AM   #126
nate_s89
So finally put the reflashed chip in. Car is running much better. Just have to put in a new thermostat and it should be good to go.
Also got rid of my tires that were too big. Anyone have any suggestions on what size I should run to fit style 32's? Rims are 17x9 and 17x8.
Old 10-22-2012, 09:07 AM   #127
SiR
Vtec just kicked in
isnt the offset all wrong?
-||Old Crayons||-
Old 10-22-2012, 09:30 AM   #128
ScotcH
Yeah, not matter what they'll look like crap and totally out of place unlesas you flare it. For actual tire size on 17", 225/45/17, 235/40/17, and 245/40/17 work best. 255/40 works as well, but they're taller.
Old 10-25-2012, 11:11 PM   #129
iverson03tj
iverson03tj's Avatar
talk to Jay - stance factory they'll find a way!
e39 M5 (s62)- Muffler Delete, Timmay Tips,
e30 325ic - Hard Top, Matte Black
e36 328is - (m52)AA S/c'd, M50 Mani, 3.23 LSD, M3 Brakes, Zimmer rotors, hps pads, Racing Dynamic Strut Bar, Depos, m3 Bumper, Intake, Spal fan, poly RTABs, Eibach Swaybars, Koni yellow, Mishimoto Rad, Silicone hose, Alumi T-housing, Depo w/LED Angels, LED tails, 12' Alpine Type R, Suede head liner, LTW Low rise spoiler
PREVIOUS CARS
92' 325is (m52) - M3 conversion AA S/c'd
'97 Euro Estroil E36 M3 Vert (S50B32)
Old 10-26-2012, 09:41 AM   #130
SiR
Vtec just kicked in
^ its not like its never been done....
-||Old Crayons||-
Old 10-26-2012, 10:39 AM   #131
nate_s89
Yeah its been done more then enough times. Just depends on how low/stiff I want to go. Probably will end up with 235/40 and 225/45. Fenders are already rolled, and if need be I will head over to stance factory and get them pulled as well.
Old 11-13-2012, 11:43 PM   #132
nate_s89
Got some new rubber all around with Koni adjustables and a mild drop. Looks much better and doesn't rub. Also completed a cooling system overhaul.
Was thinking about getting a WAR chip for ease of tuning changes. Probably going to throw in a 3.5 MAF and 24# injectors and don't want to have to keep mailing my chip back and forth to turner and getting endless $100 charges every time they make an adjustment.
Anyone have any experiences? Have done some research and so far like what I see. Also have been in contact with miller performance and they think it is more then doable with their base tunes.
Old 11-14-2012, 12:22 AM   #133
kenmar
My research from BimmerForums seems to indicate that TRM has the best tuning for normally aspirated engines; Turner has mediocre reviews. For OBD-I, the best combination I've seen for dyno results of 230-240 whp is for 21.5# injectors (apparently, it's more than adequate for N/A), 3.5" MAF on an S50 motor. I'm planning on ordering one of their chips this week for my S50 and will likely order a custom tune for my AA s/c.
Old 11-14-2012, 01:06 AM   #134
nate_s89
^Thanks for the info. I will look into that.
I hear good things about TRM, but its the same deal with mailing back the chip for a reflash. Really want to be able to do it on my own, plus you can run 4 different tunes with the WAR chip.
Old 11-14-2012, 11:35 AM   #135
cormier
cormier's Avatar
Heard good things about the WAR chip-- especially if you're doing a lot of tuning. That cost at turner would get way too much for not enough potential
I think that's the only option on the market -- unless you get into standalone systems or MS, etc
