03-27-2012, 06:28 PM
#76
The Afro-stig
Car: Is Fast. ;)
Originally Posted by sb_600
M52 cams won't fit in a non-vanos M50
from the pics it looked like he was using a vanos m50 for the build....not sure if things have changed since
03-27-2012, 10:30 PM
#77
Car: 1995 325is
I should be able to hook you up with something. I'll let you know by the end of the week.
Originally Posted by e30_kid89
I have a set of stock 328 (m52) cams.
free if you pick them up!
Thanks for the help guys appreciate it, but I managed to grab one today.
If anyone has a diff though I am on the hunt, it is the last thing I need to get this project rolling.
03-28-2012, 09:15 AM
#78
Car: e36 M52 330i
open or LSD?
03-28-2012, 11:12 AM
#79
Car: 1995 325is
Open, and the lowest ratio possible ideally.
You have any diffs you want to part with?
And a question about oil, I know this topic has been beaten to death, but did you run anything specific for your break in period?
I usually run 15-50 Mobil 1 synthetic, was just going to stick to that.
03-28-2012, 05:11 PM
#80
Car: e36 M52 330i
My buddy has a 3.91 open diff - is that too short?
For break in, I did this: http://www.mototuneusa.com/break_in_secrets.htm and ran the crappiest dino oil I could find (Formula 1 i think - from CT), then right after, switched to AMSOIL 20W50.
I used the dyno strategy but did it on an airport runway, without the cool-down in between (since I was actually driving, cooling wasn't an issue).
03-28-2012, 09:47 PM
#81
Car: 1995 325is
Awesome thanks for the info, I will read it over.
Nah I need something like a 2.93, I just sold the 3.91 I had in it. I have a 5 hour drive to the cottage every weekend I want to be able to cruise comfortably.
03-29-2012, 09:51 AM
#82
Car: e36 M52 330i
LOL yeah my bad... turns out it was to Jamie that you sold it
03-29-2012, 12:14 PM
#83
Car: 1995 325is
Haha that is correct. Has he gotten it in the car yet?
03-30-2012, 02:55 PM
#84
Car: e36 M52 330i
not sure actually!
04-01-2012, 06:01 PM
#85
Car: 1995 325is
So I got everything put back together, fired it up and it started!
Except its throwing code 1281, which is DME controle module memory supply. Does anyone have any idea what could be causing this?
Car also wont idle and is running pretty rough.
04-01-2012, 06:37 PM
#86
Car: e36 M52 330i
I was getting that same code when I rebuilt my engine.... basically you just have to have the ECU cleared. It has to do with having the ECU disconnected with the key on or something like that.
04-01-2012, 07:41 PM
#87
Car: 1995 325is
Awesome thanks, I was getting kinda worried. How do I get the ECU cleared?
#88
Car: e36 M52 330i
You either need a Peake code reader, or a BMW code reader
04-02-2012, 08:03 AM
#89
Car: 1995 325is
Once I get a diff I think I will drive it over to BMW and get them to clear it. I realized last night I hooked up the idle controller wrong and put both hoses into the manifold instead of one in the manifold and one in the rubber elbow before the throttle body.
Only thing I am missing now is the hose that goes into the hole at the bottom of the manifold closest to the firewall. Not the idle controller or the Intake Temp Sensor but there is a third hole, any ideas?
04-02-2012, 06:35 PM
#90
Car: 1995 325is
Fixed the hose it idles now. It's just running rough and really rich. Did yours do the same before you cleared the dme?
