Old 02-03-2012, 06:15 PM   #1
elroy
Is it worth it?
looking at a 2000 328ci with 185K. Engine overheated and now needs headgasket. Motor has been ripped down to the block, guess owner couldn't afford it. well he said high insurance because of tickets. Asking 4g. Would it be worth it to drop another motor in it, or attempt to fix it. I read the camshafts are delicate and can become damaged if theres tension put on them while removing/installing. How much roughly does another motor cost? Ive done some research but am finding prices from 500-1500. Is there anything else to consider with this generation?
thanks in advance
elroy is offline   Reply With Quote
Old 02-03-2012, 08:48 PM   #2
Eurostyle
Eurostyle's Avatar
$4k sounds like a lot for the car, unless its really MINT, no accident, no rust etc. Dont even bother fixing that motor, it will happen again. Coupes tend to keep more value, but even then prices have droped a LOT, you should be able to find a good one without all the hassel of engine swaps. I wouldnt pay more then $2K for that car.
Eurostyle is online now   Reply With Quote
Old 02-04-2012, 12:25 AM   #3
blakneto
blakneto's Avatar
+1 look around... you can get a more recent car, that is decent and in WORKING CONDITION...
Old 02-04-2012, 11:56 AM   #4
Lercs
Lercs's Avatar
I bought my fully working 328i for 3500.
it needed some work, but not to the extent that you have described.
Follow 8legs Racing on Twitter and Facebook
@8legsracing
www.facebook.com/8legsRacing
Lercs is offline   Reply With Quote
Old 02-04-2012, 12:34 PM   #5
Eurostyle
Eurostyle's Avatar
^^^ sedans are much cheaper then coupes! You can get one with engine problems for under $2k easy, I have found under $1k in some cases!
Old 02-06-2012, 06:45 PM   #6
elroy
i dont mind the work. i was actually looking for a cheap car with blown motor as motors aren't very hard to swap in. That being said it should be worth it/still be able to save after doing the work then it would cost to just buy one thats running and good
Old 02-06-2012, 08:23 PM   #7
ac_2007
Cruising in Top Gear
ac_2007's Avatar
Just don't plan on using anything from that engine. Also no, 4k is way too much.
ac_2007 is online now   Reply With Quote
Old 02-06-2012, 09:14 PM   #8
Randy
Randy's Avatar
yea, too much - that old crap sells for < 5G in good condition.
just thought id repeat what everyone else said, and pretend it adds value.
For Sale:
1999 BMW 323i Sedan
135 000 Km
Black on Beige
Randy is offline   Reply With Quote
Old 03-21-2012, 10:49 PM   #9
bmwins
once a head gasket is blown the engine will never be the same. you might get lucky but it usually ends up giving you more problems down the line. just save up and buy yourself a clean well maintained car. the less a car has been fiddled with, the better!
bmwins is offline   Reply With Quote
