Old 02-01-2012, 12:44 PM   #1
Pediatrick
No interior lights
I just got into my first e30. I have fixed many issues already but I don't know where to start with the interior lights. Anybody have experience troubleshooting these?
I am here: http://maps.google.com/maps?ll=50.969381,-113.959429
Pediatrick is offline   Reply With Quote
Old 02-01-2012, 12:59 PM   #2
egye30
egye30's Avatar
care to elaborate? no light comes on at all? sounds like you may have a blown fuse or something, have you checked your fuses?
1990 325i Sterling Silver Metallic/Black leather.
M52B28 OBD-I W/ S52 Cams, M50 Manifold, SS Headers, Kamotors v5 CAI, Stage 2 F1 clutch w/ 14lb chromoly flywheel, Mark D chip tune.
Bilstein Sports with H&R Race springs + E90 drop hats, F+R Strut bars, '04 330ci Steering rack (3.0 Lock to lock, 13:1), 3.15 Z3 Torsen LSD.
BBS RS's 16x8 front 16x9 rears 205/45 215/45
Old 02-01-2012, 01:06 PM   #3
Check the switch that's on the actual dome light to start. There's 3 positions, off, always on, and on when doors are open. Check both lights. If neither work, check the bulbs. If bulbs are good then check fuses. If fuses are good then check the switch on the dome light . 12v should be coming to one of the wires (for always on option).
Old 02-01-2012, 01:12 PM   #4
Pediatrick
No light comes on at all. I tested for power and no power. Which fuse should I look for. Thank you for your prompt responses
Old 02-01-2012, 01:23 PM   #5
karmatose
164.3ci Of Fury
karmatose's Avatar
Fuse #27 (30A). Also check 6(7.5A), 19(7.5A) and 21(7.5A).
Old 02-01-2012, 01:31 PM   #6
Pediatrick
You got it. I'll post back after lunch
Old 02-01-2012, 03:19 PM   #7
Pediatrick
All fuses good still no power to lights
I am here: http://maps.google.com/maps?ll=50.969203,-113.959629
Old 02-01-2012, 03:29 PM   #8
voluted
voluted's Avatar
All that's left is to check the wiring then. I had a split wire for my passenger dome light near the bottom of the B pillar which seemed like a weird spot for that wire to fatigue.
Old 02-01-2012, 03:30 PM   #9
Carib
Could be the bulbs are burnt out. The lights on my instrument cluster and HVAC panel were all burnt out. Replaced all of them and everything was okay. This was more than a year ago and the bulbs are still going. I guess the previous owner(s) didn't bother to replace any of them.
Carib is offline   Reply With Quote
Old 02-01-2012, 03:33 PM   #10
This should help
Old 02-01-2012, 04:17 PM   #11
Pediatrick
I'll have a look at the wiring tonight. Thanks for all your help
Old 02-01-2012, 05:34 PM   #12
Pediatrick
could this wire be there source of my problem? Found it on the a pillar door wiring.
I am here: http://maps.google.com/maps?ll=50.969346,-113.960373
Old 02-02-2012, 04:04 PM   #13
Pediatrick
Anybody? Been looking through the Internet but still have not found any solutions. I will be working on it tonight but don't know where to start.
Old 02-02-2012, 04:36 PM   #14
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
What lights are out exactly?
Just dome? Just console/cluster?
If you're talking about the gauge and console lights, it could be the headlight switch. There is a dimmer on it (turn headlight knob side to side), and if the dimmer quits, so do all the interior lights that run off that dimmer (dome lights are usually not affected) will not turn on at all. Does your radio work? If you think you want to try different headlight switches, there are at least three different designs that BMW used over the years. Remove yours and take it with you when hunting down a replacement.
If you're talking about the dome lights, the switch on the door jamb is usually the culprit... shitty rusted ground or sticky switch.
Grow up and move on.
Old 02-02-2012, 04:49 PM   #15
Pediatrick
Thanks for the reply. I was referring to the dome lights. I'll pull it off and check it out ASAP. Do you think that broken wire has anything to do with it?
