Old 02-01-2012, 12:25 PM   #1
SAVAGE
2001 330CIc Convertible Top STOPPED working
Hey guys,
Wondering if anyone has had this problem.
It all started a couple days before i put my car away for the winter. I went tot he put the top up, stopped it half way by releasing the button then try to start it up and again and got nothing. i Manually closed the roof and then tried to put it back down nothing budged. just a red blinking light.
I kinda wanna fix this before the spring.
anybody have an idea how to fix it or how much it would cost at the dealership?
Anything comments will help
SAVAGE is offline   Reply With Quote
Old 02-03-2012, 04:31 PM   #2
SAVAGE
Bump
Old 02-03-2012, 04:37 PM   #3
noodles101
ΛΦΕ
noodles101's Avatar
dealership will probably drain your pocket LOL...
go to a reputable bmw shop aka - rmp, stance factory, bimmersport , bimmex...etc.
Old 02-04-2012, 09:29 PM   #4
slemmer
Driving in the fast lane
slemmer's Avatar
Does it go all the way if you don't release the button half way? Sounds like a sensor problem.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 03-21-2012, 10:50 PM   #5
bmwins
Rocco at RMP, thats your best bet.
bmwins is offline   Reply With Quote
Old 06-13-2012, 08:40 PM   #6
jackadoo
Any update on this? I have the exact same problem. Thinking sensor or broken wire but if there is a quick fix, I'm all ears
jackadoo is offline   Reply With Quote
Old 06-14-2012, 08:51 AM   #7
SAVAGE
Hey, it was all fixed with stuff around the house. Here is the link of what i used. the only thing you have to be careful with is, usingan exacto knife to cut away the black meshing.
http://forum.e46fanatics.com/showthread.php?t=790169
Old 06-14-2012, 10:23 AM   #8
jackadoo
OK thanks. I saw that one too and I'll give it a go on the week-end.
Old 06-14-2012, 01:29 PM   #9
addbhp
Check your manual, if you remove your hand from the button before the light turns off (opening or closing) the top will stop and switch light will blink. You then need to wait 15 minutes before you can use the button again. It will continue to blink until it is fully open or closed even after the 15 minutes.
Cost- $0
Mark
2004 Chevy Silverado 3500 Tow vehicle
1998 323is Track toy
2001 330Cic
addbhp is offline   Reply With Quote
Old 06-14-2012, 04:08 PM   #10
jackadoo
Mine stopped on its own a few inches from the windshield and started flashing while i was holding the button I had to finish putting it up manually.
Old 07-01-2012, 05:36 PM   #11
jackadoo
Finally got to this. The brown wire was completely broken. Spliced in some new wire and used shrink wrap. Good as new!
