Old 01-31-2012, 01:31 AM   #1
Marky_mark
Detailing Specialist
Marky_mark's Avatar
Dipstick
Has anyone ever had this happen to them
So I get home and then I park my car after I filled up with gas and went to check the oil but for some reason it was hard to pull the dipstick out so I pulled it out and I look at the dipstick and i'm like wtf the plastic piece broke off so now I'm pissed because my guess is that piece of plastic is either jammed in the dipstick tube or even worse its now in the oil pan just my luck.
So now this is not going to be cheep or fun to fix
Old 01-31-2012, 04:17 AM   #2
what? You broke the plastic end cap to the distick. Use a pair of pliers/adjustable wrench to pull the dipstick (sans handle) out of the dipstick tube, and replace.
Old 01-31-2012, 11:34 AM   #3
ScotcH
I guess the piece at the bottom broke?. Replace the dipstick ... I would not worry about the plastic bit in the pan ... people have had a lot worse in there for years without knowing it.
Old 01-31-2012, 02:56 PM   #4
^^which plastic peice at the bottom? AFAIK there's only plastic at the top.
Old 01-31-2012, 04:19 PM   #5
ScotcH
There is a plastic piece at the bottom ... it's what the oil sits on for the level gauge. Maybe there are different types of dipsticks, but I've never seen one with just metal (like other cars have) ... BMWs have all had a plastic thing on them.
Old 01-31-2012, 04:28 PM   #6
Ceeker
remove the dipstick pipe, get a coat hanger and feed it through to push the plastic piece out if it is in fact stuff in the tube. then stick the tube back in with new dipstick..
just don't be a dipstick about it. :-)
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
