Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 01-31-2012, 12:32 AM   #1
Bob Marley+W
Bob Marley+W's Avatar
Parting out an S50B30 Euro M3 motor
That's correct! A 3.0 litre Euro M3 engine with individual throttle bodies.
Cylinder #1 is damaged - therefore the block is toast. The head is ported and the intake and exhaust are a work of art. However, the dome of cylinder #1 needs to be fixed (I'll take some close up pictures).
I have parted all the remaining good engine components. Coils were purchased new last summer. The alternator was re-built last summer. Intake rubber boot is brand new, have OEM headers and also a set of Supersprints.
Bob Marley+W is offline   Reply With Quote
Old 02-02-2012, 09:12 PM   #2
BmW1819
what happened rings destroyed the wall?? how bad it is repairable or new block??
Old 02-02-2012, 11:55 PM   #3
Bob Marley+W
Definitely needs a new block. There is a hole the size of an egg through cylinder wall #1. I will give the block away to someone to use as a boat anchor.
Old 02-03-2012, 12:31 AM   #4
canuckder
canuckder's Avatar
I can have?
Did you remove pistons?
canuckder is offline   Reply With Quote
Old 02-03-2012, 01:04 AM   #5
Bob Marley+W
The pistons are all out. You can have the block for free if you pick it up in South Mississauga. (send me a PM if interested)
You can see the hole in the attached pictures.
The head is a work of art - notice the nice polished intakes. The top of the dome is a bit scraped and needs some work.
Old 02-03-2012, 01:17 AM   #6
blk3
blk3's Avatar
thats a nice sized hole
Old 02-03-2012, 09:41 AM   #7
davericher20
black and blue
davericher20's Avatar
^^ thats what HE said
Old 02-03-2012, 09:58 AM   #8
Con rod failure?
Old 02-03-2012, 10:47 AM   #9
Bob Marley+W
Not 100% sure what let go.
The gasket is in good shape. The rod is bent and the piston grenaded. Who knows what let go first... ring, piston, rod?
Old 02-07-2012, 04:21 PM   #10
Roysneon
Roysneon's Avatar
Do you happen to know if the donor car was rhd or lhd? I think that the headers were made to fit either on, but can you confirm?
Old 02-07-2012, 04:40 PM   #11
Bob Marley+W
I drove it ... LHD.
Old 02-07-2012, 07:47 PM   #12
e30_kid89
The Afro-stig
e30_kid89's Avatar
How much for the oil filter housing possibly?
Old 02-07-2012, 10:11 PM   #13
Bob Marley+W
I have the oil filter housing with oil cooler line connections for $200.
The hydraulic belt tensioner and adjusting pulley are currently attached and can be yours for an extra $50
Old 02-08-2012, 09:16 PM   #14
Smikha
PM me with price for intake boot, can you verify there are no cracks in it? Also do you have the 3.5" filter while we're at it?
Smikha is offline   Reply With Quote
Old 02-09-2012, 01:12 AM   #15
Bob Marley+W
I replaced the intake boot last year as the old one had signs of wear near the corrugated section (not worth the risk to run an engine that way). So the rubber is a year old (on my car at least) with definitely no cracks anywhere. I may have the old one kicking around as a spare and you can have it if I find it. Both boots and 2 clamps for $50
Not sure which 3.5" filter you're asking about. If you're asking about the airfilter, I have an aftermarket one that I will keep.
