Old 01-29-2012, 06:08 PM   #16
Originally Posted by matty.dc View Post
I searched on google on what people were doing with the rears and some guy put on 2 POT nissan GTR calipers and an older supra rotor that were re-drilled to 4x100
I'd hate to redrill my rotor every time I tried to replace it...
Old 01-29-2012, 06:36 PM   #17
Dissembler
Dissembler's Avatar
Originally Posted by InfiniteDice View Post
I've seen pics of a jaguar swap. Not sure where, and it was a long time ago.
You mean with the in-board brakes?
S52 E30
Old 01-30-2012, 02:02 AM   #18
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
I've seen an e30 with motorbike calipers on his auto-xer. I don't remember what discs though... I'd have to hunt down the article.
Grow up and move on.
Old 01-31-2012, 04:35 AM   #19
clementine
does any one know if the calipers of the newer generation rx7(92 and up) are the same as the older generation rx7(86-91)
clementine is offline   Reply With Quote
Old 02-01-2012, 11:02 PM   #20
Chefskinny
clementine I read on another forum somewhere that they are, but don't trust my word.
What wheels are you guys running with the rx7's calipers?
Chefskinny is offline   Reply With Quote
Old 02-01-2012, 11:16 PM   #21
Dissembler
Dissembler's Avatar
Exact same. The 92+ calipers are thicker then the 86-91, but the critical dimensions are all the same, as well as the brake pads.
For a list of compatible wheels, search r3v for the "rx7 wheel fitment guide"
S52 E30
Old 02-01-2012, 11:31 PM   #22
matty.dc
matty.dc's Avatar
Just an FYI if anyone that wants to do this set-up is having difficulties finding the correct hardware around town you can use E30 flywheel bolts P/N: 11227805885 which is an M12 x 1.5 x 28mm(use these to mount the brackets to our strut housing) and use the original caliper bracket bolts to mount the RX7 caliper to your bracket P/N: 34111118948 ( M12 x 1.5 x 32mm) just in case you wanted new bolts. In both cases I believe they are grade 12.9 (imperial grade 10).
2013 Ford Edge - Daily Driver
Old 02-02-2012, 02:55 AM   #23
clementine
awesome, thanks. i appreciate it
Old 02-02-2012, 12:17 PM   #24
matty.dc
matty.dc's Avatar
I have 17 x 7 ESM 003 w/ 25mm offset on the front right now, but I will also check my Konigs which are 16 x 7 w/ 40mm offset and a 20mm spacer (which comes out to et20 wheel)
Old 02-03-2012, 07:46 PM   #25
matty.dc
matty.dc's Avatar
Final look
In the end on the et25 17 x 7 esm rims I will have to get a 3-5mm spacer for the fronts but my Konig 16x7 et40 fit nicely with the 20mm spacers
