Old 01-20-2012, 12:26 PM   #1
crxgsr
BMW
Oil leak = Head gasket?
So I noticed a bit of an oil leak this morning after driving my car to work. The oil is leaking onto the heat shield above the header, and smoking up my whole engine bay.
Does this mean head gasket is gone? Where do you guys recommend to get this done? cost?? I'm in Markham area, so hopefully somewhere not too far...
crxgsr is offline   Reply With Quote
Old 01-20-2012, 12:38 PM   #2
rider-.
valve cover gasket
Old 01-20-2012, 12:46 PM   #3
EuroSpec_92
MPOWER
EuroSpec_92's Avatar
Originally Posted by rider-. View Post
valve cover gasket
most likely
99 Estoril M3
EuroSpec_92 is offline   Reply With Quote
Old 01-20-2012, 12:47 PM   #4
Find where the leak is coming from first....
Old 01-20-2012, 01:01 PM   #5
crxgsr
BMW
Found a similar case reported on this thread:
http://forum.e46fanatics.com/showthread.php?t=882732
Where do you recommend to get this done?
Old 01-20-2012, 02:08 PM   #6
Pierce330
Pierce330's Avatar
The oil is leaking from your valve cover gasket...any independent shop can complete the repair,,,
E46 330i (Sold)
E90 328i (Sold)
E90 325i (Sold)
E90 328i Xdrive (Current)
Pierce330 is offline   Reply With Quote
Old 01-20-2012, 02:41 PM   #7
E46eNVy
BMW Service
PM'ed
If your in the Markham area, i highly recommend MVSMotors.
Great trustworthy guys. Check them out at MVSMotors.com
They deal with Porsches and BMW'S basically anything European, and then some.
E46eNVy is offline   Reply With Quote
Old 01-20-2012, 10:47 PM   #8
1bmw1
I doubt it's the head gasket, but if you're unsure, which sounds like you are, take it to one of the reputable shops on here. Bimmersport, RMP, and Pfaff just to name a few...all great shops with good BMW credibility.
Old 01-20-2012, 11:52 PM   #9
Blackedout95
Be thrilled its just a vale cover gasket
Common repair btw, 2 bimmers, 2 valve cover gaskets lol
E46
Old 01-21-2012, 12:23 AM   #10
gnome
on the roam
agreed. Vcg is a common issue after 7 years or so, had mine changed at rmp. might as well get the thermostat changed, belts, etc at the same time.
gnome is offline   Reply With Quote
Old 01-21-2012, 07:46 PM   #11
blk3
blk3's Avatar
changed mine twice in 3 years, common and no big deal to change
Old 01-22-2012, 03:06 PM   #12
crxgsr
BMW
thanks guys. Pretty straightforward DIY. Changed the VCG in about 2.5 hours. =)
