Old 01-16-2012, 10:04 PM   #1
BMe30
all by chance...
BMe30's Avatar
traction issues with winters in this weather
Has anyone else having tracktion issues with their winters with these mild temps and wet roads?
I feel like i should have gotten all seasons.
Or could it be that the car is pretty low didnt do a camber adjustment and have an lsd diff
Gone but not forgotten
Old 01-16-2012, 10:09 PM   #2
blk3
blk3's Avatar
no issues here, oh and the cheapest snow tires will be better than the best all seasons. just saying. plus who doesnt like to pitch it sideways now and again?
Old 01-16-2012, 10:40 PM   #3
BMe30
all by chance...
BMe30's Avatar
These snows are new this year. I had the same brand a few years back and no issues. I was thinking it was the moderate temps that was causing the issues. I'm at a loss....
Btw... Me Kicking it out isnt the issue... The issue is it kicks out or understeers off throttle.
Old 01-16-2012, 11:50 PM   #4
dble Trouble
TAKE IT TO THE TRACK
dble Trouble's Avatar
There's something wrong here Bruno. If you're having problems, either you put the directional tires on backwards or as you mentioned camber issues, or loose ball joints/tie rods etc. My e30 tracked like a toe missile in any winter weather. LSD can only be a help to get you going, and keeps oversteer very predictable.
Old 01-17-2012, 12:24 AM   #5
How old and what brand are the tires? Old/cheap ones wont be any better then good all seasons...
Old 01-17-2012, 12:37 AM   #6
desmo
AutoEmployee for Life
This winter I switched to new winter tires from half worn Yokohama all seasons. I can say even in the dry cold days, rain, or slush, the winters are many times better. I especially impressed in the difference in the wet, where I have more experience comparing grip between the two tires....It's much harder to brake the winters loose, but I can feel the softer winter tires roll a lot more in harder turns.
desmo is offline   Reply With Quote
Old 01-17-2012, 07:22 AM   #7
BMe30
all by chance...
BMe30's Avatar
They are nitto sn2 winters. They are brand new. I had the same tire and size 4 years ago and the car was perfect... Mind you it was still stovk then. Last winter i had used dried winters and they were ok and the car was lowered. Only changes was thr gc coilovers. The rear is lower. Maybe the springs are too stiff for these conditions?
Old 01-17-2012, 01:18 PM   #8
I can't really say that I'm having any problems with mine Bruno and I have stiffffff springs.
Old 01-17-2012, 01:44 PM   #9
BMe30
all by chance...
BMe30's Avatar
What tire size are you running on your winters?
Did you adjust your camber?
Old 01-17-2012, 01:45 PM   #10
BMe30
all by chance...
BMe30's Avatar
Im going to try to play with the tire psi see if it helps any
Old 01-17-2012, 02:38 PM   #11
195/70R14
My front camber is somewhere between -2.0 to -2.2 with 0 toe.
No provision for rear camber adjustment, not yet anyway.
Old 01-17-2012, 04:17 PM   #12
325isdan
Not to sound like a jerk, but what are your driving habbits? Understeer when letting off the throttle?? How fast are you going and how sharp are these turns?
325isdan is offline   Reply With Quote
Old 01-17-2012, 06:16 PM   #13
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
^^Bruno goes all out, all the time. His tires are so cambered in that they're half slick, half grip. He doesn't even use his brakes, he just downshifts into first. He runs 235's in the summer, and 175's in the winter. He runs his coils on full low, all the time. He runs an "is" lip in the winter. He has heated seats but never uses them.
Lets face it, its the M42 power that your tires just can't handle.
Grow up and move on.
Old 01-17-2012, 06:57 PM   #14
Deetow
That's the only possible explanation
Deetow is offline   Reply With Quote
Old 01-17-2012, 06:58 PM   #15
noodles101
ΛΦΕ
noodles101's Avatar
could the mild temp and 'wet conditon' be... maybe patches of ice?
its not so much black ice, but semi frozen ground kinda makes the pavement semi shine.
