Old 01-21-2012, 01:26 PM   #31
momax_powers
momax_powers's Avatar
but i dont think its plug and play, you gotta do some modifications right?
momaXimus
E39 IV.IV
momax_powers is offline   Reply With Quote
Old 01-21-2012, 03:14 PM   #32
Because you didn't haveXenon's to begin with, you will need to code the LCM as well as wire the AE's.
Old 01-21-2012, 11:57 PM   #33
momax_powers
i dont like the yellow halos so if i were to get the 01-03 i would have to change the AE's anyway
momaXimus
E39 IV.IV
Old 01-22-2012, 04:35 AM   #34
E36White
i may be mistaken but on units with factory AE's you'll only need to replace the bulb, with a blue-ish LED if that's your kinda thing.
Check bimmian and these sorta sites...
www[dot]bimmian[dot]com/39/LHU
E36White is offline   Reply With Quote
Old 01-22-2012, 09:40 AM   #35
+1 for BC racing coilovers from StanceFactory, give jay a call.
Old 01-23-2012, 01:23 PM   #36
TheMadChigga
TheMadChigga's Avatar
Originally Posted by noodles101 View Post
did u try callin up local bmw junk yards? they might have some headlights
Its cheaper to buy new, some of the yards want insane amount for headlights, just get DJ Auto and cheapo HID kit and get it over with, OEM headlights are expensive no matter where you get them from, my euro Hella cost me over $1k when I bought them.
And get BC, there's a lot of E39 guys that are very happy with BC's coil.
Old 01-23-2012, 01:28 PM   #37
momax_powers
can you find me a link online for bc's and how about these PSS
http://www.tirerack.com/suspension/s...oModClar=&cat=
momaXimus
E39 IV.IV
Old 01-23-2012, 02:11 PM   #38
TheMadChigga
The PSS is nice, downside is its only height adjustable, not that its a big deal, but you can't lower it much without riding bump stops on the PSS kit, unless you go to the higher end model but the price quickly climb.
Here are some basic pros and cons for the major brands:
- KW V1
Pros: its KW, so quality is there, and its pretty good when comes to rust-proof, it also rides very well and the dampening is very well.
Cons: it cost a lot, and rear lowers more than the front, the body is not adjustable hence if you lower it too much, you'll ride bump stops.
-Bilstein PSS, PSS9
Pros: Its Bilstein, and PSS is only $1000, PSS9 rides nice as well and handles nice.
Cons: PSS is only height adjustable, PSS9 is $2400.
-ST
Pros: its from KW, just with a "cheaper" brand name.
Cons: non-dampening adjust ability and body is non adjustable.
-Ground Control:
Pros: you can run whatever shocks/struts you want, since its a sleeves kit, and you can choose your spring rates if you know what you are doing, its very well built kit.
Cons: The customer service, took me 3 hrs to order replacement collars, I ran with Koni Yellows, its super smooth on daily, but I felt it was under-damp, some said with Bilstein it feels like their kidneys were about to give out, so its either one or another.
-Raceland.
Pros: Cheap, and the customer service is insanely fast.
Cons: makes you wonder what its made from.
-BC Racing
Pros: Adjustable bodies, adjustable dampening, you can choose spring rates and the shocks are match to the spring rates, it's proven in E39 world, rides well and can deal with some track events, some of the fastest customer service.
Cons: You have to adjust the bodies when lowering, or you may blow the shocks, which can be a pain.
Old 01-23-2012, 10:41 PM   #39
momax_powers
thanks for the info chigga....btw i jus put LED festoon bulbs in over my license plate and the look pretty nice
momaXimus
E39 IV.IV
Old 01-24-2012, 07:40 AM   #40
sproule905
sproule905's Avatar
I'm looking into these from Stance come spring.
Momax - if you are upgrading your headlights to the 01-03 model, you can change out the ring bulbs. Have you tried a simple google search? A lot of your inquiries can be solved with a simple search.
Old 01-24-2012, 11:49 PM   #41
momax_powers
ive researched many different options for my headlights and im going with retrofitting them by someone...hes going to put:
2 Bi-Xenon Projectors
2 Custom Projector Shrouds
Double fused/relayed wiring assembly
Full HID Kit (Bulbs & Ballasts) HighQuality
Full installation of all products
Full wiring of all products
and its gonna cost half of what it would cost to get a pair of new 01-03 factory lights
momaXimus
E39 IV.IV
Old 01-24-2012, 11:49 PM   #42
momax_powers
and ccfl rings
momaXimus
E39 IV.IV
Old 01-25-2012, 08:26 AM   #43
TheMadChigga
Ask for reference,past projects and contacts for past customers etc, retrofit is not an easy job, if he's only charging $400-500 incld the projectors, that's really on the cheap side of things, unless he's just getting an xenon pre face lifted headlights and put the angel eyes in.
Headlights are not something I'm willing to cheap out on, a crappy retro-fit job means lot of condensations build up and it can look plain hideous, not to mention causing shorts with shabby wiring.
Old 01-25-2012, 08:54 AM   #44
sproule905
sproule905's Avatar
http://www.m5board.com/vbulletin/e39...-ice-pics.html
Old 01-25-2012, 09:01 AM   #45
sproule905
sproule905's Avatar
If that link does not work, search ice angel eyes on M5board.
