Old 01-13-2012, 05:20 PM   #1
E36White
Arrow E39ers - explain the following...
Car: 2002 530i automatic with 102k miles.
Driving on a pretty rainy day, the stereo cut out a coupla times then i noticed the interior lights flickering/dimming then the xenons, and then i felt the car turn off for a split second then come back to life -- as i was still driving doing around 60-70km/h then the "trifecta" of lights came on (ABS/brakes/DSC triangle) .. i didn't feel like i lost control over the car though, as braking and steering still felt more or less normal.
The above scenario repeated itself all the way home (a good 10 minute drive).
The weird part: when I pulled up in front of my house, I put it in park and revved it a few times. The flickering was still there so I turned it off and noticed that the gearshift selector light turned off too, meaning that it had no more juice. Then it wouldn't start or even lock the doors via keyfob so I had to lock them manually. This was about 3 hours ago, I came down now to check it out and the second I pressed unlock on my keyfob, the alarm went off!
WTF?????
Back story: i was at the mall before this trip home, and i turned the DSC off and let her ass loose around the underground lot (highly polished cement surface so basically almost no friction).
What do these symptoms sound like? I experienced the same thing after a dealer visit back in december for a full checkup. But I also read somewhere that it's normal (?) after such a visit, especially if the car is put on a dyno-like device as it may throw off the DSC unit programming.
Sorry for the long post but i'm super puzzled. I don't think it's my battery as I haven't had any sort of drain otherwise.
Feedback appreciated.
E36White is offline   Reply With Quote
Old 01-13-2012, 07:55 PM   #2
v_bimmer
Jailbait FTW
v_bimmer's Avatar
sounds like your alternator went
Old 01-13-2012, 07:56 PM   #3
hellrot_M3
hellrot_M3's Avatar
Sounds like maybe a battery or alternator to me.
RMP Motors For The Win!!!!!
hellrot_M3 is offline   Reply With Quote
Old 01-13-2012, 08:57 PM   #4
carjoe
carjoe's Avatar
Alternator.
93 325is - sold!
2000 540ia- sold!
Old 01-14-2012, 01:01 AM   #5
Blackedout95
Not sure if the set up is the same on the e39 as the e46 but first thing to check is the connection to the back side of the alt. Sometimes it is as simple as it becoming loose
E46
Old 01-14-2012, 02:56 AM   #6
CBimmer
CBimmer's Avatar
That Would Be Your ALT.
CBimmer Nyce De///Meanor...
CBimmer is offline   Reply With Quote
Old 01-14-2012, 03:51 AM   #7
E36White
is it normal for it to just go out like that?
Old 01-14-2012, 04:40 AM   #8
Alternator is gone...
Old 01-14-2012, 05:52 AM   #9
E36White
okay do u recommend rebuilding it or is it better to get a new one? i don't plan on keeping the car forever..
Old 01-14-2012, 10:28 AM   #10
Blackedout95
Did you check to connection to the alt yet, is the ground tight....
If those are non issues just buy one from Eurostyle.
E46
Old 01-14-2012, 10:33 AM   #11
E36White
i swear i have a freak in my garage!
had it jump-started and drove around for a good 25-30 minutes, none of these symptoms at all. Car turned off and back on without any problems.
I'm gona go on a limb and say maybe the alt took in more water than it could handle as I couldve possibly driven thru a puddle or two...with the undercar tray missing..who knows?
Old 01-14-2012, 12:43 PM   #12
You can pretty much soak the alternator by washing the engine and never have this problem...your battery had the chance to recover and works for now, but will most likely happen again.
Old 01-15-2012, 10:33 AM   #13
E36White
okay thanks for your input..i'll check it out in the coming weeks..
Old 01-15-2012, 11:11 AM   #14
jmack
Does the 530 have the same type of computer reporting as the 540? Thinking of the diagnostic tests where you can check out the voltage the alternator is supplying while the car is running or off, giving the battery's reading.
jmack is offline   Reply With Quote
Old 01-15-2012, 11:42 AM   #15
E36White
Not sure if it does but please do share anyway and ill give it a shot.
