Old 01-10-2012, 04:19 PM   #1
hageali
87 325is- i have to pump the gas pedal to start it HELPPP PLEASE!!!!
ok so, if i park my car overnight, it starts up right away in the morning with no hesitation....say i drive it for half an hour (engine warms up) and then i park it and let it sit for about 20 minutes or so and then i go to start it again....it wont start unless i pump the gas pedal, i have no idea what the problem is...
any help would be appreciated
thanks in advance
hageali is offline   Reply With Quote
Old 01-10-2012, 04:49 PM   #2
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Cold start valve? Coolant temp sensor?
1986 E30 325e (killed)
1986 E30 325es (died)
1988 E30 325i (rotted)
1992 E34 525i (sold)
1992 E30 318i (cabrio, Dad's)
1989 E30 325i (Mom's)
1991 E30 318i (cabrio, summer car)
1991 E30 318is (Winter car)
1992 Euro M5 (driveway decoration)
1994 E36 325is (driveway junk)
Old 01-10-2012, 04:52 PM   #3
Ceeker
what is the mileage? you have what is called leak down. injectors are dirty and under short driving conditions the fuel leaks into the combustion chamber causing hard start. After initial start up - short drive - then sitting. Doesn't happen to my cars often but does happen with 2 of my 3 on occasion.
run an injection cleaning system through it - Terra clean, or remove and rebuilt the injectors.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
1 90 325is white - keepin
1 87 325i vert -red - keepin
Old 01-10-2012, 05:02 PM   #4
It's fuel related, check the Fuel Pressure Regulator or what was mentioned above. But it's easier to check for fuel pressure than it is to check for leaky injectors.
Dare I squeeze
Old 01-11-2012, 12:30 AM   #5
DIY
Permanently Dirty
DIY's Avatar
+1 to coolent temp sensor or cold start valve...
Seems like its way to rich when its warm so it probably thinks its cold....
But I wouldn't put it past leaky injectors
Old 01-16-2012, 05:19 PM   #6
Deetow
I had something similar happen, and after replacing the injectors and FPR it turned out to be the Fuel Pump.
Just be sure to check things thoroughly before throwing parts at the car.
Deetow is offline   Reply With Quote
