Old 01-09-2012, 06:05 PM   #1
ore0_dustin
ore0_dustin's Avatar
speeedo help please :(
Okay So I have a 91 e30 325i sedan.
When I got the car, the cluster was working, but the speedo and economy were in and out all the time but the tach was always working but off by 2-3000 rpms
So i took out the motometer cluster, and replaced it with a VDO cluster. Everything was working perfect, except the gas gauge. So the drove the car for an hour with speedo and everything working except the gas gauge. So anyways i swapped the gas gauge from the other cluster into this working cluster, gas gauge now works fine too.
However after replaceing the gas gauge on the cluster i left the car over night and this morning, back to original issue. No speedo no economy gauge.
Anyways So i've tried both speedos swapped em back and forth a couple times.. nothing works....
how can i test the speed sensor on the diff? to make sure its sending signal??
Input help anyone????
ore0_dustin is offline   Reply With Quote
Old 01-09-2012, 06:25 PM   #2
Ceeker
pm sent
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 01-09-2012, 07:07 PM   #3
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Originally Posted by Ceeker View Post
pm sent
You got this one duder?
Grow up and move on.
Old 01-09-2012, 07:45 PM   #4
ore0_dustin
what are your thoughts? I know that both of these speedos work. The one I just bought worked the whole way home from toronto, (1hour) and the only thing I did was change the fuel gauge, but i doubt that i harmed something inside the unit because its doing the same thing as the other cluster. No speed/economy.
Old 01-09-2012, 08:27 PM   #5
Blades
Your opinion is to long
Blades's Avatar
I thought this was going to be a thread of you stuck in one speedo size to small. I was going to say that's what you get for giving your balls azema
-=[ BL/\DES ]=-
Old 01-10-2012, 05:55 PM   #6
E30M42cab
E30M42cab's Avatar
I'd play with your diff sensor. It's probably all dirty and corroded.
Old 01-10-2012, 08:22 PM   #7
Ceeker
that's what I told him..
