Old 12-14-2011, 01:14 PM   #1
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Release Bearing
I have a feeling that my release bearing/throwout bearing is not sliding on the splines very smoothly, when it gets cold the shifter is hard to actuate until it warms up... almost like there is a lag in the movement of that bearing. There is no noise, or shuddering, it works fine when warm.
Does anyone know that if I remove the cover plate off the trans bell housing should I be able to get a small paintbrush with some lube on it up onto the splines?
Figured I'd ask before trying.
If not... I wonder if drilling a 3/4" inspection hole in the bottom of the bell housing to lube it then putting a rubber plug in the hole after could be an option. I don't think it would hurt anything.
One thing for sure I'm not removing the whole transmission to lube a spline.
Old 12-14-2011, 01:17 PM   #2
El Gato Liso
El Gato Liso's Avatar
the g260 doesnt have a detachable bell house. so you gotta pull that thing out completely.
either way the plate is very thing there is no way in hell you can get to that spline without 100% removal, and if you do you might as well put a nice new juicy bearing in there....something i should have done, 3 times...grrrrrr
R.I.P. E30
Old 12-14-2011, 01:18 PM   #3
sproule905
sproule905's Avatar
if your release bearing goes you'll hear a lovely high pitched screech.
I believe the clutch will have to be removed. unless I am confusing this with the throw-out bearing.
Old 12-14-2011, 01:25 PM   #4
InfiniteDice
It's not bad I believe in the cold it is not sliding on the splines... it's sticking. I have a spare trans, I'll take a look at it and see.
It's not like I can't drive it... but the first few shifts every day I need to double pump the clutch to get the thing in gear.
Old 12-14-2011, 01:36 PM   #5
El Gato Liso
^^maybe its your clutch pedal not building up the pressure, check that too
R.I.P. E30
Old 12-14-2011, 01:53 PM   #6
How old is your brake fluid?
Old 12-15-2011, 12:50 AM   #7
This.
Also: release bearing just easily slides around on the spines, I don't see how anything but a worn one could cause problems. Unless you're approaching 0 degrees calvin, I can't see it shrinking THAT much.
Old 12-15-2011, 09:52 AM   #8
Originally Posted by MaxBell View Post
0 degrees calvin
I'm interested in this also because my shifter is difficult to engage after I've released the clutch once. I have a spare bearing and transmission, but I'm not sure what the problem is.
Old 12-15-2011, 05:24 PM   #9
Some things to test. Is your pressure plate worn out? Could be not getting enough clearance to pull it back into 1st. Go coast at speed in neutral, with the clutch in, put it into 2nd, then immediately into first and let the clutch out. Does that make it easier?
Another thing I was thinking is (obviously) the synchros. Does it have a faint whining noise when you do get it into 1st?
Could it be a clutch stop that is set too high? Try taking that out and testing for any change.
When is the last time you changed the tranny fluid?
How old is the shift carrier bushing (and the rest of the shifter bushings for that matter)?
The final (and most likely) issues is worn dog rings and synchronizer rings. That's something that I'd leave to the pros though.
Old 12-16-2011, 12:38 PM   #10
InfiniteDice
- YES it goes into 1st easier once it's been in another gear. I replaced the ball and the spring on the lever... I don't really see how that lever could wear out, I mean the last I seen it it had some shiny spots where it touches the release bearing and the ball. My concern is that perhaps when I installed the release bearing I didn't apply enough grease to the input shaft spline and it's not sliding.
- Sometimes when cold it has that 'going backwards' whine/chirping.
- No it usually shifts at just past the 1/2 down mark on the clutch travel.
- New Amsoil gear oil 1 month ago. Brake fluid is 2 days old total flush 2x.
1.5 years old along with a z3 2.8 shifter. all new shift linkage... it's a bit trickier than the stock shifter but I can tell a difference on a cold morning. Like something is sticking/not sliding.
At this point I wouldn't be worrying about it, it's not that big of a problem since it goes away after it's warm, it's more of an annoyance every morning in the winter.
Thanks for the ideas.
Old 12-17-2011, 09:49 PM   #11
North
Both of these describe my g260 well. I feel like I'm going to choose to live with it and let it slowly die rather than be proactive though.
North is offline   Reply With Quote
Old 12-17-2011, 10:30 PM   #12
Ceeker
I have a cabrio with an extremely stiff shifter. I am not entirely sure if your problem is similar but I crawled under the car and sprayed the crap out of the linkage a good few times and it has gradually loosened up. So If I am mistaken please correct me. But how does the shifter have anything to do with the release bearing. I thought that was clutch related?
I would change the gear box fluid to redline or purple. it will clear up syncro problems and problematic shifting in cold weather. the bmw gear fluid isn't very user friendly with cold climates.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 12-19-2011, 09:28 PM   #13
BmW1819
tranny is coming out no way of cleaning the spline when u install it don't use alot of lube cause dirt will collect and hang it up
Old 12-19-2011, 10:26 PM   #14
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Definitely not the release bearing, when it fails it makes noise when using the clutch pedal (whirring noise), if it gets stuck then the clutch pedal is extremely stiff or does not fully release, but that almost never happens. What kind of tranny fluid do you have in there? Try some nice synthetic atf.
Old 12-20-2011, 12:25 AM   #15
Yep. I pretty much broke it in half, and it made a VERY loud high-pitched squealing noise whenever the clutch was pushed in.
