Old 12-12-2011, 07:19 PM   #1
goldhawk
Offset vs. centered front CAB's
I have to replace the front CAB's on my e30 - considering if I should go with offset ones (M3 style).
So, basically I'm doing a whole overhaul on the car, new motor and all. It'll be used mostly for street driving when I'm done, maybe a few track and autoX days here and there.
I'm just wondering if the extra caster added will hurt my everyday driving and sharp autoX turning.
Also, putting offsets into the lollipops would be a little more work (I'd want to put in some set screws to hold them).
I'm likely going with the 75d CAB's from AKG - so opinions on these are welcome.
Also, on the rear I'm going with the AKG 80A subframe and diff bushings that raise the rear subframe 9mm... Any experience for anyone here?
goldhawk is offline   Reply With Quote
Old 12-12-2011, 07:48 PM   #2
daveed
The extra caster won't make a big difference, it's not as dramatic of a mod as everyone says it is. Just a firmer bushing.
daveed is offline   Reply With Quote
Old 12-12-2011, 08:14 PM   #3
If you do go with the AKG bushing definitely put a set screw because they aren't that tight of a fit (you can tap them in with a hammer). I didn't and mine rotated fairly quickly. Had to take them off and re-orient them and put a set screw.
Old 12-12-2011, 08:32 PM   #4
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
For mostly street driving, OEM E30 M3 or 95 M3 offset rubber bushings are the cats ass.
Old 12-12-2011, 10:58 PM   #5
ismail
ismail's Avatar
Mods sticky this thing - I asked this exact question 2 weeks ago except for an e36, pretty much got the same answer though.
ismail is offline   Reply With Quote
Old 12-13-2011, 07:58 PM   #6
goldhawk
Ok thanks. Talked to some local guys too
I guess I'm gonna go with OEM... maybe M3, not sure yet
Old 12-13-2011, 09:27 PM   #7
DR.ZED
I speak from experience. The difference wasn't dramatic but definitely a great mod I noticed. The car had quicker turn in but you need to get used to unwinding the wheel after a slow speed turn.
Contrary to what the above poster says its amazing what just a degree of difference can do to a suspension.
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 12-13-2011, 10:58 PM   #8
BMe30
all by chance...
BMe30's Avatar
Go with the m3 offset then when you go for alignment get e30 m3 toe setting
Gone but not forgotten
Old 12-14-2011, 12:40 PM   #9
The Twin
The Twin's Avatar
I put M3 offset CAB's in my e30 vert.
feel absolutely no difference...unless you track it, do it up.
otherwise, it's simply asking for a placebo mod and premature tire wear.
The Twin is offline   Reply With Quote
Old 12-14-2011, 01:11 PM   #10
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Get the m3 ones... waaaay stronger/better feel.
Old 12-14-2011, 04:18 PM   #11
Roysneon
Roysneon's Avatar
I couldn't imagine putting the stock bushings back in imo, too much empty space and not enough rubber/poly for me.
Old 12-14-2011, 05:30 PM   #12
Axxe
Axxe's Avatar
No premature tire wear with a proper alignment.
Also, if you don't want offset, but still want solid OEM rubber, go with 96-99m3 CABs. They are solid rubber and centered, as 96-99m3's had their caster modified through different geometry control arms.
