Old 12-09-2011, 09:57 PM   #1
oakville46
Replacing Backing Plates
Has anyone replaced the backing plates on the rear brakes? The section where the parking brake shoe pins hold on have rotted away now on mine and I need to replace those shields/plates. Anyone done this? easy for an afternoon job in the driveway?
oakville46 is offline   Reply With Quote
Old 12-09-2011, 10:17 PM   #2
Ceeker
try using a bolt and nut. usually works to hold them on. or put washers behind the pin hole to keep the pins in place.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 12-09-2011, 10:34 PM   #3
oakville46
Already did that ... the hole has gotten bigger now so I figured I would replace the whole plate instead ... plus the pins got bent since they came out and I've put some km's on them like that. Simply cars fixed me up with my brake job last year on this ... I figure if its easy, I'll just do it myself now.
Old 12-10-2011, 12:55 AM   #4
Renboy
Assuming it will slide over the hub then you should be able to do it in less than an afternoon. Should be: remove wheel, remove caliper with bracket, remove rotor, remove parking shoes, remove plate and reverse. If you can't slide it over the hub, then I suggest parking on flat surfaces.
A Saturday afternoon, in a driveway, in December, in Canada?
Old 12-11-2011, 10:57 PM   #5
oakville46
You'r talking to a guy who washes his car in the driveway in January/February if the weather is warmer than -1 LOL
Old 12-14-2011, 11:19 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Easiest way is to cut the new plate to slide it over in a strategic way, and then having it welded up next time you're at an exhaust shop (from the back, shot of paint and done). Won't be an issue until it rots out the next time.
Old 12-14-2011, 11:23 PM   #7
blk3
blk3's Avatar
^^^^^^^ what he said. i just did mine on monday. backing plates does not slide over the hub. thats why you have to cut it. or remove the wheel bearing hub. if you need bearings do it properly. if not the cut and weld works just fine
Old 12-14-2011, 11:49 PM   #8
oakville46
Got the car at Bimmersport getting it done along with my sport suspension changeover and any other little things I need done ... not enough time on my hands to tackle these projects.
Old 12-15-2011, 01:46 AM   #9
Axxe
Axxe's Avatar
Sometimes it's just easier to pay the credit card bill than mess around when you're out of time.
Old 12-15-2011, 10:14 PM   #10
oakville46
^^exactly ... however the bill was super small thanks to John and the staff at Bimmersport. They installed the washers for me instead of replacing the backing plates. Much better than all that work and money
Old 08-11-2013, 07:08 PM   #11
aberg83
aberg83's Avatar
Hate to revive an old thread but wondering if anybody has a picture of the nut and bolt or washer method of securing the ebrake pins?
aberg83 is offline   Reply With Quote
Old 08-11-2013, 08:06 PM   #12
Ceeker
bolt through the back of plate and shoe and a washer/nut to secure it.. pretty simple
Old 08-12-2013, 08:34 PM   #13
aberg83
aberg83's Avatar
Can you access the holes in the backing plates from behind? Quick look under the car with a flashlight and I couldn't see them.
Old 08-12-2013, 10:34 PM   #14
Ceeker
they can be a tight fit but accessible.
