Old 12-11-2011, 11:55 AM   #16
radi0activem
Originally Posted by MaxVQ View Post
BMW are like Princesses, they demand a lot and don't take well to getting old.
Corrected
Brian
2003 530i
radi0activem is offline   Reply With Quote
Old 12-11-2011, 04:36 PM   #17
Oyster
Send a message via MSN to Oyster
only the e39 are like PRINCESS, my e46 325xi was low maintenance compare to the 540!
Oyster is offline   Reply With Quote
Old 12-14-2011, 04:46 PM   #18
MLue1
MLue1's Avatar
Some times there is a fix:
http://www.bimmerboard.com/forums/posts/25594
Price $2
http://www.pelicanparts.com/cgi-bin/...0Each%20%20%20
Mark
'99 E39 540iT
Old 12-14-2011, 09:05 PM   #19
jmack
Nice, going to add that to my parts list.
jmack is offline   Reply With Quote
Old 12-14-2011, 11:56 PM   #20
MLue1
MLue1's Avatar
If you're sure it won't break ya
I'm told... a few peeps (including indies) have replaced the Behr rad without knowing that baby comes out.
Mark
'99 E39 540iT
Old 12-22-2011, 02:34 PM   #21
5style
Lala-land
5style's Avatar
Originally Posted by Axxe View Post
^it cost me $120 for the fan and relay kit, and about an hour to install and hook it up. Way better than engine driven fan.
This. I have a electric puller from the factory, 100% better then a fan clutch
Old 12-24-2011, 01:06 PM   #22
MLue1
MLue1's Avatar
Lightbulb Update
Originally Posted by MLue1 View Post
UPDATE: I had this leak and did this fix last weekend. When I rocked the nipple it was loose and there were traces of dried up coolant around the base of the bong (my slow coolant leak found). I followed the instructions but it is not complete. The barbs will break off when removing the nipple, I can't see how the poster was able to recover the barbs as they are designed to secure the nipple on the rad and to be a one time install, so when you remove the nipple they will break off. If you are going to do this it is a 5 minute job if you loosen the fan shroud and the nipple comes out intact but it will take longer if you do it properly. I would suggest draining the coolant, remove the upper rad hose and extend a rag or something that will fit in the upper rad pipe to catch the barbs when the nipple is removed.
The new nipple fits perfectly (tight), refill coolant and bleed the cooling system and you are done. This is one of the easiest fixes if you need to do it.
Mark
'99 E39 540iT
