Old 11-27-2011, 03:03 PM   #1
StraightSix
StraightSix's Avatar
Braking Issue
So recently I've had this weird braking issue with my 330ci. When i brake lightly the car pulls slightly to the right as if the front left caliper isn't engaging. As I apply more pressure to the brake pedal I feel a slight "click" in the pedal and the car then starts to brake in a straight line. It's as if the left front caliper only engages after a certain amount of pressure.
What could be causing this?
Any help would be greatly appreciated!
StraightSix is offline   Reply With Quote
Old 11-27-2011, 09:49 PM   #2
BmW1819
maybe your caliper is starting to seize up
Old 11-27-2011, 11:42 PM   #3
StraightSix
Yeah i was thinking that too. I'm going to try bleeding the system first. If that doesn't fix it then i'll look into a caliper rebuild kit. I want to get this done before the snow comes. Braking with one wheel in the snow can't be safe.
Old 11-27-2011, 11:52 PM   #4
1bmw1
Yup, if the car is pulling to the right, then it's an issue with the left caliper or the hose. First thing i would do is check and see that everything is in place such as sliders and pads, and that everything is bolted on properly. Since you are hearing a clicking noise and then it fixes temporarly on it's own, then it might be yours pads are not on properly.
If everything seems like it's properly installed, and you don't see anything funny, then i would try and bleed the caliper on that side. Since it's pulling to the right then this suggests that your left caliper isn't engaging. After this doesn't fix it, then it might be time for a new caliper or a rebuild kit.
Old 11-28-2011, 02:02 AM   #5
Other then your brakes, your suspention/steering components CAN and will cause pulling under braking. IF you have too much play in a ball joint or a bushing, during hard stops it will change the geometry of the suspention (or alignment) and the car will not go straight. From what i can remember, even rear control arm bushings will cause it. Do all your check before, even tire pressure can affect things
Old 11-28-2011, 09:04 AM   #6
StraightSix
That's exactly what I'm going to be doing haha. I've already checked everything in that area and nothing seems out of place. I'm thinking it could very likely be that there's air in the system which would describe the clicking noise. As I'm pushing down on the brake pedal the air is being compressed until it reaches a certain pressure, at that point the caliper releases and engages. That sudden release of the caliper is what I think is causing the clicking feeling I'm getting in the pedal.
I kinda ruled out the suspension/ steering components as it only happens under light braking. If it was suspension related I think it would get progressively worse the harder you brake, whereas with my car, it only pulls to one side under light braking but sort of fixes itself when braking moderately hard. I've checked all the wheels for any sort of play and they all seem to be fine so I think this is strictly a brake issue.
Old 11-28-2011, 09:34 AM   #7
Start with servicing the brakes, making sure all sliders are free.
Old 12-04-2011, 02:41 AM   #8
E46330iguy
Check out the brakes and see if one side is worn more than the other, while you have it lifted up check the front end for play anyways Also check your tire wear and pressures they can also effect pulling while braking and the main thing is the roads, If the roads are grooved badly braking can pull the car to one side all the time
Winter Authority When Hell freezes over,we'll play Hockey there too
Search for Oil Threads NEVER make a new one!
BMW Oil Info
KONI /Michelin/Stoptec/ Bimmerbrake / MTechII/AA Stage one (for now)
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Tags
brake pressure, brakes, braking problem, car pulls to one side
