Old 11-23-2011, 07:37 PM   #1
BADRAT
badratart.com
BADRAT's Avatar
Question Steering Wheel Removal
hey just wondering if anyone has experience removing this steering wheel and airbag. any tips would be appreciated as i could not find i diy, im looking to add the obc signal stalk.
thanks in advance
not my pic
BADRAT is offline   Reply With Quote
Old 11-24-2011, 01:37 AM   #2
ScotcH
disconnect the battery, and DOT NOT connect it until you have it all back together (air bag plugged in). Otherwise, your SRS light will come on, and you'll need to get it cleared.
Other than that, it's pretty easy. SOme torx bolts in the back of the wheel (hard to see, they hold on the air bag). The center bolt is 15mm I believe, and you might need a wheel puller to get it off. An impact gun makes the center bolt removal easy.
Old 11-24-2011, 01:45 AM   #3
^^^16mm bolt, no puller needed on this one.
Old 11-24-2011, 09:47 AM   #4
Ceeker
did you know there is still a charge left in the SRS system even though you disconnect the battery? Static electricity can set the air bag off...
I would be extremely careful and leery about removing this if you don't have such experience. Make sure the air bag is not pointing at you or facing down. If it goes off, you'll have a 100mile/hr projectile coming your way.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 11-24-2011, 05:06 PM   #5
Renboy
The airbags have a built in safety grounding tab that prevents static from discharging the airbags. You don't even need to disconnect the battery to do this. Just don't put the key in the ignition until everything is put back together.
Old 11-25-2011, 11:15 AM   #6
StikiGreenZ
StikiGreenZ's Avatar
I just did this last week (thanks Renboy for the stalk ). I was done within an hour.
I unplugged the battery and let the car sit for 30 minutes as per the DIY I found online.
Good luck!
BMW 645i - Black on Red
Old 11-25-2011, 11:09 PM   #7
BADRAT
badratart.com
BADRAT's Avatar
anyone have any obc stalks for sale?
Old 11-27-2011, 09:50 PM   #8
BmW1819
no need for a new stalk, open her up and solder the wires
Old 11-27-2011, 10:03 PM   #9
BADRAT
badratart.com
BADRAT's Avatar
Can you elaborate on this?
Sent from my BlackBerry 9800 using Tapatalk
Old 11-28-2011, 12:13 AM   #10
We have a "few"!
Old 12-01-2011, 10:58 PM   #11
BADRAT
badratart.com
BADRAT's Avatar
thanks for the stalk eurostyle, installed! just need to have the obc enabled and im ready to go
Old 12-09-2011, 12:26 AM   #12
BADRAT
badratart.com
BADRAT's Avatar
Alarm, Key fob window roll up, transmission reflash, and obc programmed at stancefactory.com def worth the drive
Old 12-09-2011, 12:44 AM   #13
steve.325i
transmission refresh ??
USA-Spec iPod Interface Comparison
DIY: H11 Foglight to HID Conversion
steve.325i is offline   Reply With Quote
Old 12-09-2011, 12:49 AM   #14
BADRAT
badratart.com
BADRAT's Avatar
software was reloaded, wanted to make sure it was up to date
Old 06-21-2013, 05:53 PM   #15
HaMmErHeAd
HaMmErHeAd's Avatar
I am currently having this problem with the on board computer stalk not cycling. I believe the wire to be broken inside the stalk. I have bought a soldering iron along with solder to fix this problem, but do not feel confident about doing this DIY:
http://www.bimmerforums.co.uk/forum/...-button-t36778
Anyone who has done this before or need this done also? I wouldn’t mind compensating with a little bit of $ for your time and effort.
HaMmErHeAd is offline   Reply With Quote
