Old 11-20-2011, 07:24 PM   #1
avguy
aka e30bim
Help me identify this part
Looked on realoem.com for an hour and giving up. My car is a 2003 540i Wagon, on the driver side bank, there are two studs for 10mm nuts located on wiring casing for the wires that connect to the ignition coil pack harnesses.
There is a bracket that is held down by the nut on the stud closest to the firewall. The bracket has two plastic clips that hold hoses connected to this bracket. Can someone identify part #'s for these 2 plastic clips? The one I'm specifically looking for supports a coolant or oil line.
If you can get me a part # you're a pro.
Thanks again.
avguy is offline   Reply With Quote
