Old 11-15-2011, 11:19 PM   #1
hellrot_M3
hellrot_M3's Avatar
540i clutch question?
Does removing the cvc valve from the clutch help with clutch response in 6spd 540i's?
RMP Motors For The Win!!!!!
hellrot_M3 is offline   Reply With Quote
Old 11-16-2011, 09:17 AM   #2
TheMadChigga
Taiwan Panda Racing Unit.
TheMadChigga's Avatar
Send a message via ICQ to TheMadChigga Send a message via AIM to TheMadChigga Send a message via MSN to TheMadChigga
I think you mean the clutch delay valve?
yes, it makes a huge difference.
Volvo project
E39 project
Old 11-16-2011, 01:17 PM   #3
O ya, I meant to get mine removed this past season.
www.enthusiastauto.caContact if you are looking for a car
His--2000 BMW ///M5 .:Jet Black on Black:. Individual - Style 65 Wheels; 9.5" Square Set up;275 Tires;10mm/3mm Spacers; Black Kidneys;Muffler Delete; 3.5" Dual Tips; Beast Power Sway Brackets; "Dinan" Ducts; E60 SSK; BC Coils
Hers--2000 BMW ///M5 .:Avus Blue on Grey/Black:. '01 Exterior Upgrades; E60 SSK
Old 11-16-2011, 02:14 PM   #4
dcramer
what I really don't get is that people actually sell valves with the delay taken out. Who would buy one of these when you can just remove them ?
Old 11-16-2011, 03:41 PM   #5
cormier
cormier's Avatar
Lmao for that "oem" look :p
Old 11-16-2011, 04:34 PM   #6
hellrot_M3
hellrot_M3's Avatar
Ya sorry that is what i mean, thanks TheMadChigga.
Going to remove it at RMP Motors, thanks guys.
Derek
Old 11-16-2011, 04:47 PM   #7
dcramer
just remove it, it's not hard. I've taken 3 of them out. Even if you completely drain the master cylinder just fill it back up and pump the clutch back up.
Last one I did drained the master cylinder, pedal was dead, fill the brake master back up, pump the clutch and away you go.
--dc--
Old 11-16-2011, 05:05 PM   #8
cormier
cormier's Avatar
You don't have to bleed the slave at all?
Old 11-16-2011, 05:08 PM   #9
dcramer
Even if you did it's not difficult. Just put tubing on the bleed screw and open it. It is close to the master and will flow easily.
But no I didn't have to bleed it.
Be warned though you are going to get brake fluid on you. It will be pissing out when you open the line.
Dave
