11-14-2011, 04:41 AM
#1
Car: none
Buying my first 03-06 BMW ///M3
-Whats up guys, i'm new to this forum..to speed things up im looking to purchase a 2003-2006 BMW m3 coupe for the first time.
-This will be my first BMW i would be buying.
-Just got out of the JDM scene, also sold my RSX type s and now moving on to a new project.
-Can anyone shed some light on me about the m3's and what i should look for/be concerned about before purchasing?
Thanks in advance
11-14-2011, 10:17 AM
#2
Car: need a turbo on it
Get a ppi done
Watch for
Subframe crack
Vanos
Smg problem if u r thinking aBout one
Otherwise, it is just like any other car
MM6 Mesh Wheel / AP Coilover Suspension Kit / Federal 595EVO tires / ///M3AN ONE Black Ceramic Coated Header / Hightech cats / Hightec x-pipe / DTM muffler / D2 Racing Sports BBK / rust paint
Coming soon: 3m di-noc cf wrap airbox
11-14-2011, 11:08 AM
#3
Vtec just kicked in
Car: 99 S52
Thanks in advance
http://edgemotorworks.com/index.php?...d=25&Itemid=55
-||Old Crayons||-
11-15-2011, 12:20 AM
#4
Car: none
thanks
11-15-2011, 12:41 AM
#5
Car: 330ci SC, M5 Touring
Welcome to the dark side!
First i would say stay away from SMG, way more headaches then 6spd!
Spend as much as you can afford to get a clean car, if you go cheap, you will pay for it later on. Look for something with few owners, LOTS of records, no accidents...Be carefull as most M's get driven hard!
11-15-2011, 01:33 AM
#6
Car: none
i have like 25,000 for one..but i have not yet to find a clean one with low km in toronto
11-15-2011, 01:36 AM
#7
it will take time to find a clean one.
good luck
or you can just get a cheap one, and replace all the stuff.
11-15-2011, 02:16 AM
#8
If I was you, I would get a super clean 330ci ZHP then spend the $10k in mods and have an M3 killer! Almost any used car you get will need new suspension and brakes soon, and if you are going to replace anyways, why not upgrade! At that point you have something with NEW parts, way better then low milage OEM.
11-15-2011, 06:17 AM
#9
Car: 325i, 335xi
"...well-documented tendency of the 2001-2002 S54 to suffer connecting rod bearing failure in the E46 M3" ( http://en.wikipedia.org/wiki/BMW_M_Coupe). But if you're looking for a low mileage 03-06 M3, the early production cars with the bad bearings should not be a problem
11-15-2011, 08:30 AM
#10
Car: M3,328is,F250, CRV
Lots of info on this site as it is M3 specific
http://m3forum.net
03 AW on LSB M3 coupe, BMW motorsport 4.10 Diff, AA Exhaust, OEM CSL rims, Aero Res, TMS subframe, powerflex bshgs, Macht Schnell, Vorsteiner diffuser, TMS steel lines etc..
Complete Comp Pkg Upgrade
98 328is hamann HM2,3.23 diff, ZKW headlights, HID fogs, M3 front, sides, rear and mirrors.UUC rsc36 exhaust, fk coilovers, X brace,UUC tran mounts. Spal fan, Mishimoto rad, AKG rtab, Pweflex CAB. Rogue RSM,SS clutch line, m3 subframe plates, pf bushs
09 F250, 2012 Honda CRV winterbeater
11-15-2011, 09:04 AM
#11
Car: e36 m3
Originally Posted by Eurostyle
First I would say stay away from SMG, way more headaches then 6spd!
I think that is a bit of an over-exaggeration, yes it does cost more than a manual to fix/maintain if the pump or actuator goes, but it is still less costly than a auto rebuild. It's basically the same transmission, same clutch, just a few more parts to control the clutch and the gear lever.
I wouldn't say that's enough reason to stay away completely from SMG without knowing what the OP is looking for. It serves a different purpose than a traditional manual does.
11-16-2011, 04:29 PM
#12
Car: none
been searching everywhere cant find a clean m3!
11-16-2011, 04:37 PM
#13
Vtec just kicked in
Car: 99 S52
it will take months...unless you luck out.
-||Old Crayons||-
11-16-2011, 06:12 PM
#14
Car: 2005 BMW M3
www.m3forum.net
A clean low milage one pops up under the for sale section every few weeks. Only problem is their all in the USA
