Old 11-11-2011, 11:38 PM   #1
Ahlavanthan
1995 Honda Prelude SRV
Looking to sell my Black 95 SRV. Stock body with a very good condition leather interior. Car runs very well.
I should be the 4th owner. Car will come E-Tested and with Safety.
Good:
Car has only 198K kms on original engine.
Tinted
Alarm
Rebuilt calipers all around with new pads and rotors this month
New clutch cylinders
New MagnaFlow Cat.
Replaced Radiator
A/C filled this summer
Pioneer MP3 deck with USB
Stock Spoiler
Good Thread on all 4 tires on stock rim
Everything works, including power antena and heated mirrors and seats.
Bad:
Some rust starting on rear fenders.
Rust on sunroof panel - will include glass roof from 5th Gen
ABS lights are on, haven't had a chance to fix.
Loud exaust for some
Speckers need to be upgraded
Selling because I am looking for a smaller SUV before winter and have no room for a third car in the garage.
Asking $3700 or B.O
** 18" Chrome Konig Monsoon rims on 95% new tires optional , ( they were never on this car ) **
Some specs of you are not familiar to this model.
4th Generation
Year '92-'96
Model S Si Si VTEC
ENGINE
Type Aluminum-alloy in-line 4
Displacement 2156 cc 2259 cc 2157 cc
Horsepower@rpm (SAE net) 135@5200 160@5800 190@6800
Torque (lb.ft.) 142@4000 156@4500 158@5500
Compression Ratio 8.8:1 9.8:1 10.0:1
Valve Train SOHC, 16-Valve DOHC, 16-Valve DOHC, 16-Valve VTEC
Fuel Induction System PGM-FI
Ignition System Electronic
EPA Estimate (manual) 23/29 22/26 22/26
EPA Estimate (automatic) 23/28 22/27 N/A
DRIVE TRAIN
Type Front-Wheel Drive
Manual Transmission 5-Speed
Automatic Transmission 4-Speed N/A
Final Drive Ratio (MT/AT) 4.06/4.29 4.27/4.43 4.27/NA
BODY/SUSPENSION/CHASSIS
Body Type Unit Body
Suspension 4-Wheel Upper Wishbone, Lower Control Arm
Stabilizer Bar (mm, front/rear) 25.4/23.0
Steering Type Variable-Assist Power Rack-and-Pinion
Steering Wheel Turns, Lock-to-Lock 2.9
Turning Diameter, Curb-to-Curb (ft.) 35.9
Brakes 4-Wheel Power-Assisted Disc 4-Wheel Power-Assisted Disc w/ABS
Wheels 14-inch Steel Wheels w/Full Covers 15-inch Alloy Wheels
Tires 185/70 R14 87H 205/55 R15 87V
EXTERIOR DIMENSIONS
Wheelbase (in.) 100.4
Length (in.) 174.8
Width (in.) 69.5
Height (in.) 50.8
Track (in., front/rear) 60.0/59.6
Ground Clearance (in.) 5.7
Curb Weight (lbs., MT/AT) 2809/2862 2866/2921 2932/NA
Coefficient of Drag (Cd) .33
INTERIOR DIMENSIONS
Headroom (in., front/rear) 38.0/35.1
Legroom (in., front/rear) 44.2/28.1
Shoulder Room (in., front/rear) 54.0/50.6
Hiproom (in., front/rear) 52.2/41.4
Cargo Volume (cu. ft.) 7.9
Interior Volume (cu. ft.) 80.2
Ahlavanthan is offline   Reply With Quote
Old 01-17-2012, 11:45 PM   #2
Ahlavanthan
Price reduced to $3000 or B.O
