Old 11-08-2011, 01:07 PM   #1
Kapetan
95--525i Rear brake job
Hey Everybody..
I just purchased 1995 525i, and I am new to the BMW world. I am replacing rear rotors and pads this weekend (parts bought and will be picked up at Maranello, a little drive from Hamilton, hopefully it's worth the trip).
For some reason I have only one sensor for rear brake linings (on passenger side), should there be another one on driver side or not? And where does it disconnect?
Kapetan is offline   Reply With Quote
Old 11-08-2011, 10:47 PM   #2
MaxVQ
Nope, there is one one the front and one on the rear. BMW assumes brake wear is the same one the same axe.
No need to disconnect the wear sensor. Simply remove it from the old pad and clip it on the new pad.
MaxVQ is offline   Reply With Quote
Old 11-09-2011, 07:55 AM   #3
Kapetan
By the looks of it, the wear sensor was sliced off, that's why I have to replace the whole sensor.
Old 11-09-2011, 09:58 AM   #4
MaxVQ
I see... I think the wear sensor wire should lead to connector somewhere on the strut.
You can also simply strip the end of the wire, twist them together and tape them up. This will disable the sensor, but will turn off the brake wear light.
Old 11-09-2011, 10:48 AM   #5
Kapetan
great.. i will check it out.. thank you very much
