Go Back   maXbimmer Forums > Platinum maXbimmer Sponsors > StanceFactory
Old 08-06-2012, 04:58 PM   #76
ALPINA MAN
ALPINA Collector
ALPINA MAN's Avatar
Originally Posted by Marky Mark View Post
Thanks for the update Alpina Man!
And if any trouble makers show up on this thread I've got you covered!
Thanks man!
1983-E28-Euro 525I-S54 M Motor - 6 speed, S3:73 LSD Diff
1986-E28-Alpina B7 Turbo #259
1988-E32-Alpina B11 #189
1991-E34-Alpina B10 #523
1997-E39-Alpina B10 V8 #221
2011-Audi S3 TFSI Quattro-6 Speed (winter beater)
ALPINA MAN is offline   Reply With Quote
Old 08-17-2012, 06:43 PM   #77
And with business card clearance from calipers to wheels all around, I present the S54 E28's new brake hardware.
6-piston fronts
4-piston rears
It stops.
Old 08-17-2012, 06:54 PM   #78
#SaveTheManuals
So perfect. Love the bright red calipers.
'12 M3 6MT Alpine White + Fox Red Extended | '09 328i 6MT Space Gray + Black
Old 08-20-2012, 12:19 PM   #79
Those brakes mean business!
Follow me on Instagram @SEVEN40iL and Twitter @SEVEN40iL
Old 09-10-2012, 05:04 PM   #80
ALPINA MAN
ALPINA Collector
ALPINA MAN's Avatar
Yesterday I dynoed the car at an event in Kitchener (euro car show) and the result was impressive, I should mentioned that the first time that we did dyno the car, it was just completed by Stance Factory and this time we went through the ECU and engine adaptation and since the dyno was available, I was curious as what would be the result, so after two runs the result was 291 HP and 265 T. in comparison to previous dyno result I gained 11 HP and 24 T.
Old 09-10-2012, 06:03 PM   #81
EMPOWERD
EMPOWERD's Avatar
Nice numbers Sia! Was that SAE or STD? Smoothing?
My YouTube video
-- RANDY SPARRE --
Old 09-10-2012, 08:23 PM   #82
ALPINA MAN
ALPINA Collector
ALPINA MAN's Avatar
This is just a quick reference about SAE and TSD.
“(SAE:
"SAE (Society of Automotive Engineers), USA. Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25°C). This SAE standard requires a correction for friction torque.
STD:
STD is Another power correction standard determined by the SAE. Power is corrected to reference conditions of 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5°C). Because the reference conditions include higher pressure and cooler air than the SAE standard, these corrected power numbers will always be about 4 % higher than the SAE power numbers. Friction torque is handled in the same way as in the SAE standard."
Here is some quick math (using assumptions and round numbers):
STD:
Air Temperature: 60F
Absolute Pressure: 29.92 inches Hg
Relative Humidity: 0%
Relative Horsepower : 104.8%
Air Density: 1.223kg/m3
Relative Air Density: 99.8%
Density Altitude: 67feet
Virtual Temperature: 60F
Vapor Pressure: 0 inches Hg
Dyno Correction Factor: .955
SAE:
Air Temperature: 77F
Absolute Pressure: 29.23 inches Hg
Relative Horsepower : 100%
Air Density: 1.157kg/m3
Relative Air Density: 94.4%
Density Altitude: 1952feet
Virtual Temperature: 77F
Dyno Correction Factor: 1)”
I am not sure it was to busy to ask the technician, but you should know, weren’t you there?
Old 09-10-2012, 10:06 PM   #83
EMPOWERD
EMPOWERD's Avatar
It usually says on the print out
My YouTube video
-- RANDY SPARRE --
Old 09-10-2012, 11:15 PM   #84
ALPINA MAN
ALPINA Collector
ALPINA MAN's Avatar
Oh, I will check it out, I got the print out after so I honestly didn’t look at all the details closely, I will check it out and let you know.
Old 09-11-2012, 12:28 AM   #85
sparf328
boostjunky
sparf328's Avatar
nice numbers, what does your car weigh? must be a blast to drive
sparf328 is offline   Reply With Quote
Old 09-11-2012, 02:40 AM   #86
cormier
cormier's Avatar
Brakes, awesome. Dyno results also awesome. Congrats man!
Old 09-11-2012, 11:02 AM   #87
ALPINA MAN
ALPINA Collector
ALPINA MAN's Avatar
The original stock 525i weigh about 2800 Lbs., but since I upgraded the brakes and wheels and some other goodies such as sport manual lather interior instead of original cloth interior etc…, so I believe the weight this car is around 2900 or slightly over but still under 3000 Lbs..
I can not tell you how much fun it is to drive this car, it feels like a go cart in triple dose of steroids.
Cormier Wrote;
Thank you very much!
Old 09-11-2012, 11:26 AM   #88
Marky Mark
Excellent dyno results AlpinaMan!
I heard there was a lot of interest and spectators at the Kitchener show when the 525 was on the rollers........if you know what I mean.
Marky Mark is offline   Reply With Quote
Old 09-12-2012, 10:51 AM   #89
NOTORIOUS VR
NOTORIOUS VR's Avatar
Awesome thread! Amazing swap, love the e28
Great work again SF, S54's seem to be your thing!
Old 09-14-2012, 10:09 AM   #90
E46carbonM3
M3 Carbon Fiber Junky
E46carbonM3's Avatar
Send a message via AIM to E46carbonM3 Send a message via Skype™ to E46carbonM3
I happen to be there to witness the dyno and this amazing piece of work
E46carbonM3 is offline   Reply With Quote
