Old 10-19-2011, 01:43 AM   #1
clementine
318 is acting weird
hello everyone. my car just recently started acting funny, it happened after a rainy day. it seems to loose power randomly when driving, and it idles really rough, to the point where sometimes it just turns of, also the check engine light will go on.
any suggestions?
thanks.
clementine is offline   Reply With Quote
Old 10-19-2011, 05:42 AM   #2
E36is
'OldSchool..'
E36is's Avatar
check for bad coils, arcing spark plug wires, or loose spark plugs. and make sure all high tension leads are secure.
Old 10-19-2011, 05:57 AM   #3
BMe30
all by chance...
BMe30's Avatar
Unplug the icv
See if that helps
BMe30 is online now   Reply With Quote
Old 10-19-2011, 11:02 AM   #4
Deetow
Unfortunately with that description almost anything could be wrong with your car. I would start by checking the vacuum hoses for leaks, then as has been said move onto the ignition/spark system. If those both check out move onto the fuel system. These 3 could be the culprits. The vacuum is easiest to troubleshoot and the fuel is the hardest.
I had a similar problem with my last 318 and it turned out to be the #4 injector which was shitting the bed and dumping way too much fuel into the cylinder.
Chris
Deetow is offline   Reply With Quote
Old 10-19-2011, 12:12 PM   #5
Ceeker
^ I agree..start with the easiest and most cost efficient way first.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
1 90 325is white - keepin
1 87 325i vert -red - keepin
Old 10-19-2011, 05:33 PM   #6
clementine
what ive done
spark plugs
ignition wires
and no change.
i also forgot to mention that i forgot to put my gas cap back on(thus loosing it), prior it raining, and think water may have entered the tank. but i have already put additive in there to get the water out and nothing has changed, and this is the third fill up.
Old 10-19-2011, 05:42 PM   #7
BMe30
all by chance...
BMe30's Avatar
unplug icv
Old 10-19-2011, 11:47 PM   #8
Check that your battery is connected nice and tight. My car would do funny shit like that and that was the problem.
Old 10-20-2011, 12:49 PM   #9
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
But you've put another gas cap back on right?
1986 E30 325e (killed)
1986 E30 325es (died)
1988 E30 325i (rotted)
1992 E34 525i (sold)
1992 E30 318i (cabrio, Dad's)
1989 E30 325i (Mom's)
1991 E30 318i (cabrio, summer car)
1991 E30 318is (Winter car)
1992 Euro M5 (driveway decoration)
1994 E36 325is (driveway junk)
Old 10-21-2011, 11:09 AM   #10
clementine
hahaha
yes i have.
Old 10-21-2011, 05:18 PM   #11
BMe30
all by chance...
BMe30's Avatar
Originally Posted by BMe30 View Post
unplug icv
lol i have a feeling
Old 10-21-2011, 05:26 PM   #12
E30M42cab
E30M42cab's Avatar
unplug icv
At what point does this become a mod? haha
Got a clogged fuel filter or failing pump?
Old 10-21-2011, 05:30 PM   #13
BMe30
all by chance...
BMe30's Avatar
it sounds exactly like the issue i had with my icv.. would idle so rough and sometimes stall out... even if that didnt happen i noticed that under slow driving conditions the motor would cut in and out and start to bog on me... i unplugged the icv and no issue since... and that was before the itb swap...
Old 10-22-2011, 12:24 AM   #14
clementine
unplug icv
hmm i dont think its that because even when im driving on the highway, i will try to keep a stable speed at 100km/h at roughly 3000rpm and my car will start to slowly decrease in rpm and speed until i give full throttle, then it will regain its speed again until the next spudder occurs. but i guess it wont hurt to unplug the icv.
thanks alot for all the suggestion, i appreciate it
Old 10-22-2011, 12:28 AM   #15
clementine
i changed the fuel filter and no change. but as for the pump i dont know. usually with a failing pump i find the idle is ok but when giving gas it struggles, for my issue its the total opposite.
