Old 10-16-2011, 06:21 PM   #1
El Gato Liso
El Gato Liso's Avatar
weird engine heating problem....no idea wtf prob is...
i've pulled the cooling system of my m50 tons of times...
my problem. maybe an hour of idling...coolant gets too hot and bubbles out of the reservoir pressure hose *the skinny one that dangles*
i've changed the heater core, and the tstat. any idea why this would happen after the car has been idling for quite a bit, heater getting hot on full blast?
thanks.
R.I.P. E30
Old 10-16-2011, 06:28 PM   #2
Ceeker
you've got air in the system. bleed it with the car on a slight hill with the nose facing up.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 10-16-2011, 06:29 PM   #3
El Gato Liso
been there done that. bled it enough times, and after an hour of idling and occasional reving....KABLOWWWWW.
R.I.P. E30
Old 10-16-2011, 06:43 PM   #4
Ceeker
I beg to differ....you still either have air in the lines or you have a waterpump on it's way out. but I would bet on air... I've had this happen to me enough to know. AIR AIR AND STILL MORE AIR! it is trapped somewhere in the block most likely in the back. You should also make sure you have the heat on full when bleeding as your air could very well be sitting in the heater core.
Old 10-16-2011, 07:00 PM   #5
Blown head gasket. It can be fine up to a week, slowly accumulating air in the cooling system, and then it gets too much. Seen it many times on Subaru's known for HG problems
Old 10-16-2011, 07:01 PM   #6
noodles101
ΛΦΕ
noodles101's Avatar
headgasket problem? causing more pressure to the cooling system?
Old 10-16-2011, 07:05 PM   #7
Ceeker
yes I've heard this also.
Old 10-16-2011, 07:09 PM   #8
Yes, can also be a crack, but those usually are much bigger and build a LOT more pressure.
Old 10-16-2011, 07:11 PM   #9
noodles101
ΛΦΕ
noodles101's Avatar
yeah happend to my M52, lol... parked my car and had it idle for maybe 2 minutes and then kaboooooom , over flow tank blew up. lol
Old 10-16-2011, 11:32 PM   #10
El Gato Liso
^^ thats whats happening! except over a much longer period.
if its a bad HG. I would rather pull this engine and dump it, unless the head is still fine, then m52 block! although im sick and tired of working on this car lol.
we'll see...
thx for the input. its also burning coolant too. lots of white smoke on a cold start.
R.I.P. E30
Old 10-17-2011, 01:42 AM   #11
egye30
egye30's Avatar
im gonna bet my money on a bad water pump.. unless you recently had it changed..
1990 325i Sterling Silver Metallic/Black leather.
M52B28 OBD-I W/ S52 Cams, M50 Manifold, SS Headers, Kamotors v5 CAI, Stage 2 F1 clutch w/ 14lb chromoly flywheel, Mark D chip tune.
Bilstein Sports with H&R Race springs + E90 drop hats, F+R Strut bars, '04 330ci Steering rack (3.0 Lock to lock, 13:1), 3.15 Z3 Torsen LSD.
BBS RS's 16x8 front 16x9 rears 205/45 215/45
Old 10-17-2011, 08:20 AM   #12
Ceeker
we'll see...
hmm..on start up that could just be the cold start -cold motor, but if you are losing coolant -does it smell sweet? then you know you've got a blown head gasket.
Old 10-17-2011, 10:36 AM   #13
blk3
blk3's Avatar
^^^ if its thick white smoke then its a headgasket
Old 10-18-2011, 10:30 AM   #14
nachos23
SweetXi
nachos23's Avatar
I'm still putting my money on the air issues..... Had the same with my car when not properly bled
My Rides:
2009 335Xi
520HP
H&R coilovers
BBS LM wheels
//M sport package
BMW Personal Audio System
2000 Z3M
Conforti tuned
AFE CAI
++More to come this winter
Old 10-18-2011, 12:56 PM   #15
El Gato Liso
well compression test resulted about 210psi per cylinder, with like 2 adjacent cylinders reading about 195 or just below 200psi
i dont get this m50....dont get it at all, but its burning coolant. what a head ache...
im going to try and do the coolant again....*sigh*
R.I.P. E30
