Old 10-16-2011, 06:21 PM   #1
El Gato Liso
El Gato Liso's Avatar
weird engine heating problem....no idea wtf prob is...
i've pulled the cooling system of my m50 tons of times...
my problem. maybe an hour of idling...coolant gets too hot and bubbles out of the reservoir pressure hose *the skinny one that dangles*
i've changed the heater core, and the tstat. any idea why this would happen after the car has been idling for quite a bit, heater getting hot on full blast?
thanks.
El Gato Liso is online now   Reply With Quote
Old 10-16-2011, 06:28 PM   #2
you've got air in the system. bleed it with the car on a slight hill with the nose facing up.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
Old 10-16-2011, 06:29 PM   #3
El Gato Liso
been there done that. bled it enough times, and after an hour of idling and occasional reving....KABLOWWWWW.
Old 10-16-2011, 06:43 PM   #4
I beg to differ....you still either have air in the lines or you have a waterpump on it's way out. but I would bet on air... I've had this happen to me enough to know. AIR AIR AND STILL MORE AIR! it is trapped somewhere in the block most likely in the back. You should also make sure you have the heat on full when bleeding as your air could very well be sitting in the heater core.
2 325i 4 dr - sold
Old 10-16-2011, 07:00 PM   #5
Eurostyle
Eurostyle's Avatar
Blown head gasket. It can be fine up to a week, slowly accumulating air in the cooling system, and then it gets too much. Seen it many times on Subaru's known for HG problems
Old 10-16-2011, 07:01 PM   #6
noodles101
ΛΦΕ
noodles101's Avatar
headgasket problem? causing more pressure to the cooling system?
Old 10-16-2011, 07:05 PM   #7
yes I've heard this also.
2 325i 4 dr - sold
Old 10-16-2011, 07:09 PM   #8
Eurostyle
Eurostyle's Avatar
Yes, can also be a crack, but those usually are much bigger and build a LOT more pressure.
Old 10-16-2011, 07:11 PM   #9
noodles101
ΛΦΕ
noodles101's Avatar
yeah happend to my M52, lol... parked my car and had it idle for maybe 2 minutes and then kaboooooom , over flow tank blew up. lol
Old 10-16-2011, 11:32 PM   #10
El Gato Liso
^^ thats whats happening! except over a much longer period.
if its a bad HG. I would rather pull this engine and dump it, unless the head is still fine, then m52 block! although im sick and tired of working on this car lol.
we'll see...
thx for the input. its also burning coolant too. lots of white smoke on a cold start.
Old 10-17-2011, 01:42 AM   #11
egye30
egye30's Avatar
im gonna bet my money on a bad water pump.. unless you recently had it changed..
Old 10-17-2011, 08:20 AM   #12
we'll see...
hmm..on start up that could just be the cold start -cold motor, but if you are losing coolant -does it smell sweet? then you know you've got a blown head gasket.
2 325i 4 dr - sold
Old 10-17-2011, 10:36 AM   #13
blk3
blk3's Avatar
^^^ if its thick white smoke then its a headgasket
Old 10-18-2011, 10:30 AM   #14
nachos23
SweetXi
nachos23's Avatar
I'm still putting my money on the air issues..... Had the same with my car when not properly bled
My Ride:
2004 330Xi
DCT Electronic Shifter
Bilstein and H&R sports suspension, Rogue Enginerring Race Brace
AA Stage2 tuning
Conforti CF Cold Air Intake
Hamann Front Spoiler and Side Skirts
BMW OEM rear wing spoiler.
M3 SMG Paddle Steering Wheel and M3 Seats
18" M6 custom painted wheels
Custom red kevlar interior
Magnaflow Exhaust
VIS CF Hood
Old 10-18-2011, 12:56 PM   #15
El Gato Liso
well compression test resulted about 210psi per cylinder, with like 2 adjacent cylinders reading about 195 or just below 200psi
i dont get this m50....dont get it at all, but its burning coolant. what a head ache...
im going to try and do the coolant again....*sigh*
