Old 10-11-2011, 02:43 AM   #1
325isStephen
Drifter
Sr20'd e30
Haven't been around max much in the last while, but figured I'd post this up here too
Friend of mine known as Deathlens on most forums took these shots for me. Almost time for hibernation/build time again, so this is pretty well it for the year.
Mod/ Changed list:
Exterier
Euro grills
Euro trims
Euro plate filler
Euro smillies (bosch)
OEM fog blanks
OEM shadowline window trim
Mono wiper
Interior
black OEM carpet
Black OEM speaker covers
Black headliner
Clarion headunit
Mtech 2 steering wheel
Euro glove box handle
OEM Tan sport seats front
Rear seat deleted
Sound deadening removed
Motor/drivetrain
Sr20det engine and transmission
Fresh engine rebuild
Greddy rocker stoppers
ARP head studs
Bings alloy vented coilpack cover
Mines tuned ecu
Hallman Boost controller
Custom Throttle cable
Custom FMIC piping
Vibrant couplars
T-bolt clamps
Mishimotto intercooler
Apex'i blow off valve
ISIS v2 stainless tubular exhaust manifold
ISIS 3" stainless turbo elbow
Custom 3" Stainless turbo elbow back straight pipe
Custom engine mounts
Custome transmission mount
Custom 2 piece drive shaft
Reinforced, notched, stripped and rustcoated subframe's
Stainless gel coated clutch line
Custom wire harness
OEM e30 m3 engine wiring covers
OEM m42 radiator
12" electric slim fan
4:10 lsd
Brakes
Stainless gel coated flex lines
r32 skyline Brake master
r32 skyline Brake booster
OEM rebuild calipers front
OEM rebuild calipers rear
New rotors front
New rotors rear
New pads front
New pads rear
New ebrake cables
New ebrake spring kit
New ebrake shoes
Suspension
Custom shortened front strut housings with IX shocks, eibach 6" springs
5" eibach race springs rear/ tokico shocks
Custom steering linkage
e36 3.2 turn rack, spaced up half inch
New e36 tie rods
New control arms
New M3 offset control arm bushings
New front sway bar links
New sway bar bushings and brackets
New subframe bushings
New differential bushing
New rear sway bay links
New rear sway bar bushings
New trailig arm bushings
Wheels
BBS RS 16x9 et -6, 16x8 et 4
Falken 205/40 rear, yoko S drive 195/40 front
Steve's E30 by DeathLens | MJB Photo, on Flickr
Shot by Mad Hatter:
H20i 2011 by .Mad Hatter., on Flickr
and bay shots by various people at h20i
Rear shot
Check out www.ScrapedCrusaders.com for more of Deathlens and Mad Hatter's work
Old 10-11-2011, 04:11 AM   #2
The car is looking sick Steve.
Old 10-11-2011, 05:29 AM   #3
cormier
cormier's Avatar
Awesome ride man. 4.10 tho? That's gotta rippppp eh! Hey any pix of the skyline booster?
Old 10-11-2011, 08:31 AM   #4
jeremy
NICE! Not diggin' the single wiper position though.
Old 10-11-2011, 09:59 AM   #5
325isStephen
Drifter
Thanks dude.
Yes 4:10, silvia is 4:08 stock, revs at 2500ish at 100kms with a top speed of 285kms (mathematically).
I'm going to try and get some detailed pics, i'll try to grab one of the booster.
Old 10-11-2011, 10:59 AM   #6
Pretty sure you know I like this.
Old 10-11-2011, 09:21 PM   #7
Nick_V
Nick_V's Avatar
If it was mine, I'd want the rear wheel fitment to match that of the fronts (perfect) and a little less rake. Those rears are a little much IMO.
Sick sick car though.
Old 10-12-2011, 02:00 AM   #8
325isStephen
Drifter
Yes, yes I do
That's the plan, already have 4 lug center's in the works to eliminate adapters and bring the wheels in, then I'll be able to run the rears in the front with an 8mm spacer putting the wheel in the same place up front as it is now, and make the rears 10's with 3.5inch lips and still be 6mm in, allowing me to drop the rear more.
Old 10-12-2011, 11:45 AM   #9
Love it.
Old 10-12-2011, 08:44 PM   #10
blk3
blk3's Avatar
car looks great, bet it goes like stink
Old 10-12-2011, 10:00 PM   #11
BmW1819
wow great build steve
Old 10-12-2011, 10:19 PM   #12
HavocSteve
Does it need to get any lower? Might as well get air!
Old 10-13-2011, 12:21 AM   #13
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Looks good, but I bet you're no fun to drive around with any more. I liked you better when you were doing M20 D-slaps redlining first at 90kph (turns out you can only do that 5 times though... who knew!?) and I kinda miss the stinger exhaust. Glad to see you got the engine back in (or is that a replacement mill?).
Grow up and move on.
Old 10-13-2011, 01:45 AM   #14
325isStephen
Drifter
Thanks man, I know I know, I haven't been any fun this year, as you can see, was busy doing work!
After I did the swap in the winter, I drove the car for a few weeks.... and then it decided it'd like to spin a bearing. So I stuffed the car in the corner and didn't look at it for a few months. After a while I started ordering parts, and with a couple months worth of work and money I got it back together in time for h2oi, barely had time to put 500kms on the motor before it made the 1100km trip each way there. I'm trying to make sure i'll be at the autocross this weekend, hopefully all goes well!
Old 10-18-2011, 09:14 AM   #15
E30M42cab
E30M42cab's Avatar
So with the mono wiper, do you have a cowel grill with no wiper hole on the drivers side? You could probably pick up a RDH grill which would finish it nicely if you haven't already.
