Go Back   maXbimmer Forums > Platinum maXbimmer Sponsors > RMP Motors
Old 10-08-2011, 10:59 PM   #1
BlueBimmer09
Creaking sound from Rear passenger side
Hi,
Recently I have been hearing a slight creaking sound from the rear driver passenger side of my bmw 330ci. The sound is coming from the bottom of the car.
This sound happend when I engage the clutch at low speeds. The sound is the strongest in first gear when I start at low speeds.
Do you have any idea what the problem might be and how much It might cost to fix.
BlueBimmer09 is offline   Reply With Quote
Old 10-09-2011, 08:56 PM   #2
craigIS
A.K.A. crossfire291
craigIS's Avatar
Take a look at your rear shock tower mounts. One, if not both are probably torn. This sounds like the beginning stages of the issue. Eventually both will tear, and you'll hear the sound all the time.
Go to the truck and lift up the carpet around the wheel wells. If there is an issue with your mounts, it will be obvious.
The other problem this could be is the rear control arms. Have a look at this too, but I'm gonna say it's your mounts almost for sure.
flickr
Old 10-16-2011, 06:03 PM   #3
ToccaTocca
Before we guess like Canadian tire techs, did you get this checked out by a professional?
ToccaTocca is offline   Reply With Quote
Old 10-17-2011, 08:33 PM   #4
BlueBimmer09
No, I did not get a checked yet. Been too busy with work to do anything, I might drop by RMP to get it checked when I get a chance.
