Old 10-07-2011, 07:16 PM   #1
jasonbaek
Clutch kit for 1.6L M40?
My clutch is on its way out so I would need a new clutch kit soon.. As far as I know m40 uses different clutch and it has lighter flywheel..
I searched for a supplier but no luck so far. I also saw a post form another forum that clutch kit for non-a/c 318IS fits but I'm not entirely sure if it's true.
If anyone know the place where I can get the clutch for this euro m40, or clutch kit from other model that would fit into m40, let me know..Thanks
jasonbaek is offline   Reply With Quote
Old 10-07-2011, 07:49 PM   #2
Ceeker
check on e30tech.com or R3vlimited. Both exclusive e30 forums. I'm sure someone there can help.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 10-07-2011, 08:42 PM   #3
Pretty sure that post was correct about the clutch kit. Your car has the same flywheel as an M42 powered car, so chances are the clutch kit is the same. I probably can get you one if you are interested. PM me.
Old 10-07-2011, 08:51 PM   #4
Roysneon
Roysneon's Avatar
The flywheel on M40 cars are a euro part, lighter than the 318is flywheel. The M42 clutch should go just fine, though.
Old 10-07-2011, 09:05 PM   #5
Gah, fail. Yeah you are right, 11221739315 is up to 3/90... didn't see that at first (since we don't have 318s before '91). 21211223550 is the dual mass shit flywheel. Dunno if that clutch would work then, pressure plate depth may be different?
Old 10-08-2011, 03:08 AM   #6
jasonbaek
http://realoem.com/bmw/showparts.do?...g=05&lang=enUS
It's bit confusing to read but I don't think m42 clutch would fit into m40. I still wonder if non-a/c m42 clutch will fit into m40 though(part # is different).
I also found a sach clutch kit for 1990 318i wihtout dual mass flywheel(so I suppose it's an m40) at bavauto.com. And it's currently on clearance sale. What do you guys think?
Old 10-08-2011, 02:49 PM   #7
Roysneon
Roysneon's Avatar
Just get rid of the M40. Once mine needs a clutch that will be my solution.
Old 10-08-2011, 03:00 PM   #8
daveed
My buddy swapped out the m40 in his touring for an m20 because the m42 water pump didn't bolt up.
daveed is offline   Reply With Quote
Old 10-08-2011, 03:59 PM   #9
Roysneon
Roysneon's Avatar
To what?
The M40-M42 swap has been done a bunch of times.
http://www.r3vlimited.com/board/show....php?t=195298&
If you have specifics on what problems he encountered, post away, I might find the info very useful in the future
Old 10-08-2011, 04:11 PM   #10
411
411 is offline   Reply With Quote
Old 10-08-2011, 04:49 PM   #11
daveed
To what?
lol reread my post - an m20b25. As far as I know he didn't run into any problems aside from running a single exhaust.
Old 10-08-2011, 04:56 PM   #12
Roysneon
Roysneon's Avatar
Sorry, I meant what did the water pump not "bolt" up to? Did he just need different rad hoses?
Old 10-08-2011, 04:58 PM   #13
daveed
ahh, the water pump on his m40 needed replacement
Old 10-08-2011, 05:20 PM   #14
411
Old 10-08-2011, 05:23 PM   #15
411
............""nice"....."sig"
