Old 09-29-2011, 09:48 PM   #1
greenmachin6
Fluctuating idle at stop
When i come to a stop the idle dips below normal then spikes a bit after about three or four times it flattens out to a normal idle
any help would be much appreciate
thanks
greenmachin6 is offline   Reply With Quote
Old 09-30-2011, 01:00 AM   #2
blakneto
blakneto's Avatar
does an error light show? Check your MASS AIRFLOW SENSOR and your AIR FILTER to be sure they are both clear and clean. I figure those are easy to check? Air filter might have to be replaced.
Old 09-30-2011, 03:29 AM   #3
greenmachin6
thanks just replaced the MAS will check the filter such a minor issue could be the fix,
here's one for ya just replaced front and rear rotors and pads with good quality thick cross drilled rotors and ceramic pads for 135$ including taxes and shipping just put in E46 rotors on ebay place was out of Ontario
Old 09-30-2011, 07:21 AM   #4
Blackedout95
Did you check the air meter first, also oem or nothing imo, you get what you pay for. For $135 your gonna be doing the job again real soon, sorry but just what I see.
E46
Old 09-30-2011, 11:36 AM   #5
crxgsr
BMW
it's most likely a vacuum leak somewhere. maybe a vacuum hose has a crack.
crxgsr is offline   Reply With Quote
Old 09-30-2011, 02:10 PM   #6
blakneto
blakneto's Avatar
Yah i hear there are some good spots of guys making rotors in TO.
I got front rotors when i had a Nissan Altima and they served me well!
Unless they are using some sort of amazing metal alloy... but its always buyer beware.
There are enough good deals on stock OEM rotors in TO that you may not have to go the ebay route... just depends.
Old 10-02-2011, 04:03 PM   #7
oakville46
$135 for pads and rotors??? Hope they don't fall apart after the first hard braking moment.
As for the idle issue, check for any vacuum leaks. Had it happen to me and I found a small crack in my vacuum line - replaced it and all good again.
oakville46 is offline   Reply With Quote
Old 10-11-2011, 11:58 AM   #8
E46Dude
Respect ur Parents.
Vacum leak. Had the same thing, had to get it changed and cleaned the system and that fixed it.
Fix it fast, eventually it can lead to multiple error warning lights along with the fluctuating idle.
E46Dude is offline   Reply With Quote
Old 10-12-2011, 01:31 AM   #9
new member
Most likely its the lower intake boot, most common problem.
If its not that, then its your ICV, clean it up and go.
It its not that then clean your MAF or potentially replace it.
What year is your car ? auto or stick?
Old 10-13-2011, 08:53 PM   #10
duramax
duramax's Avatar
idle
my 2002 m3 does the same thing, replaced the airmass sensor and still does it. the engine shakes when i come to a stop or at a light but not every time
got any tips
duramax is offline   Reply With Quote
Old 10-13-2011, 11:42 PM   #11
new member
M3s are different, way different.
Could be your precat O2 sensors , could be your vanos.
Old 10-14-2011, 08:36 AM   #12
duramax
duramax's Avatar
idle
the funny thing is there is no engine light or codes.I was told that the m does funny things at idle
