Old 09-26-2011, 04:44 PM   #1
Mardin
@__@
Trans Fail Safe, left me stranded
Hello,
Might need the best minds on this one as I'm about done with this money pit.
P0720 Output Speed Sensor error code, along with BMW codes 121, 120, 132, 106. 1st Gear Ratio, 2nd Gear Ratio, Input/Turbine error in no particular order.
Car is in limp mode and had to get towed to mechanic. Diagnosed battery and alternator and both are fine. Ignition Switch replaced last year. Switched camshaft position sensor last month and everything was gravy until... now.
What's next? Change output speed sensor? Anyone experience this before? Sort of sad at 150,000KM one owner.
Regards,
Martin
Mardin is offline   Reply With Quote
Old 09-26-2011, 10:49 PM   #2
MLue1
MLue1's Avatar
Lightbulb
If the Trans Fail Safe Mode resets when the car cools down then check out this thread I posted and linked to my original post on bimmerforums.
http://www.maxbimmer.com/forums/showthread.php?t=144481
Good Luck
Mark
'99 E39 540iT
