Old 09-13-2011, 11:34 AM   #1
champ0202
Steering wheel vibrates?
- I have had my drive shaft balanced, and replaced the u-joints. Both front bearings and rear bearings have been replaced. Shocks, struts, and strut mount bearings also replaced.
- When doing speeds over 100km the steering wheel will vibrate sometimes worse than others. When doing right turns between 60km - 80km (highway ramps) the steering wheel vibrates excessively.
- Under breaking the car does not pull and the wheel does not vibrate.
I am not sure what else to check or replace, does anyone have any suggestions?
champ0202 is offline   Reply With Quote
Old 09-13-2011, 12:12 PM   #2
crxgsr
BMW
did you balance your rims & tires?
Old 09-13-2011, 12:58 PM   #3
champ0202
I did last summer, just to be safe I just removed the tires and all the weights appear to still be on. (sometimes they can fall off if the rim wasn’t clean when weights applied.)
Old 09-13-2011, 01:10 PM   #4
crxgsr
BMW
Even under normal driving, the balance can be off.
I would suggest minimum rotation, otherwise, re-balance the wheels.
Old 09-14-2011, 01:55 AM   #5
blakneto
blakneto's Avatar
Check your control arm bushings and/or your control arm ball joints...
Or... your front suspension work is "suspect".... double check those.
Just me 2 cents...
Old 09-19-2011, 09:57 PM   #6
jabela
What kind of tires do you have and how many KM on them?
2002 E46 325ci // 5spd // Sport Suspension
www.modernapothecary.ca
Old 10-01-2011, 06:47 PM   #7
duramax
duramax's Avatar
steering wheel
your steering shaft knuckle is wore out its the one that is near the steering rack looks like a alumium box
duramax is offline   Reply With Quote
