Old 07-16-2013, 02:45 PM   #91
Woofer
Woofer's Avatar
Sorry, I meant to say the brown m20 coolant temperature sender.
After looking at some write ups, I realize that my m52 obd2 head will not accept the m20 coolant sender. My options are to rethread the sender to the proper size or buy one that is made to fit from the link below.
"You will need to use an e30 brown top coolant temp sensor for the cluster reading. This will replace the pipe that screws into the head for the throttle body coolant line. You have three options here
Option 1 (what I did): Use a die and change the pitch of the threads to match the s52 head threads. The pitch was m12x1.5 (could be wrong, double check)
Option 2 (more risky IMO): Tap the head to match the sensor threads.
Option 3 (expensive, but easy if you don't have the tools: Buy a already rethreaded brown top coolant sensor from Markert motorwerks. http://www.markertmotorworks.com/MMWProducts.html"
Full write up here
http://www.r3vlimited.com/board/showthread.php?t=266738
Old 07-17-2013, 12:33 PM   #92
cormier
cormier's Avatar
So what's the verdict then ?
Old 07-17-2013, 01:58 PM   #93
karmatose
164.3ci Of Fury
karmatose's Avatar
I'd go option 3 because I'm lazy.
"She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. " - Han Solo
Old 07-17-2013, 04:42 PM   #94
Woofer
Woofer's Avatar
^^Lol I thought about option 3, but didn't want to wait.
I went with option one. I rethreaded the sensor. On my way to the shop to install it. Hopefully get everything else all hooked up and fool around with the tranny a bit. I think I installed the bracket wrong. I am using the stock m20 tranny, g260 I believe. I have a bracket that's suppose to correct the angle/tilt that its on when mated to a 24v motor. Hopefully she's on the road this weekend.
Old 07-17-2013, 09:14 PM   #95
karmatose
164.3ci Of Fury
karmatose's Avatar
I'm no swap expert, but I surf the interwebz a lot. I believe the raised part of the brace goes on the left hand side of the car. It really looks like it can only go in one way.
Old 07-24-2013, 12:47 PM   #96
Woofer
Woofer's Avatar
^^ thanks for your input.
I did have the brace on properly te first time. I guess my biggest problem was trying to use my steel shifter carrier bracket. I ended up using a later style e30 aluminum carrier and now it lines up perfectly.
I also ended up rethreading the coolant Sender and now I should be getting a reading to the cluster
The whole drivetrain is in and now it's plug and play from here.
I can finally see some light at the end of the tunnel lol!
Old 07-24-2013, 12:59 PM   #97
Woofer
Woofer's Avatar
Also finally got around to the brakes.
New calipers, rotors, pads and SS lines.
Lots more parts to go on. Hoping to fire it up this week.
Stay tuned! Lol
Old 07-24-2013, 01:23 PM   #98
are we racing for slips?
Old 07-24-2013, 01:34 PM   #99
Woofer
Woofer's Avatar
Lmao. Depends, if you want to lose tht cute roadster of yours!!
Old 07-24-2013, 06:22 PM   #100
cormier
cormier's Avatar
What beautiful brakes. Enjoy them while they last
Old 07-29-2013, 03:16 PM   #101
Woofer
Woofer's Avatar
And she breathes!!!! Sounds crazy straight off the headers. Ill see if I can post a vid later.
Just a few thing left before she's on the ground.
-e34 m50 throttle cable
-bleed brakes and clutch
-mount my remote brake res. (any suggestions? I read the the 2002 tii brake res is the best option. Trying to use my e34 540 remote res. just can't find a spot to mount it really. Can anyone confirm if the Brake res is suppose to be above the master cylinder? I am assuming it is suppose to be above because it needs to drain into the master cylinder. If not, I can mount it just under the intake boot.
-change my valve cover gaskets and paint valve cover
-spark plugs
-install exhaust and get a down pipe made
-clean up wiring and get e30 318/m3 beauty covers ( anybody have any laying around lol?
-new m50 valve beauty covers
-install vaders maybe even install the rear e36 m3 bench.
-put front end back together
I'm sure there are a few more things but I'd like to get the above finished before the end of this week.
A few pics
Before
After
Also, does anyone have the chrome rings that go around the e30 headlights?
Old 07-29-2013, 07:14 PM   #102
Slowered318
Nice work!
I should be on the road this weekend too.
Old 08-24-2013, 08:35 PM   #103
thomase30
thomase30's Avatar
Yeah the res has to be above the master it feeds fluid by gravity and will leak out the cap
thomase30 is offline   Reply With Quote
Old 08-25-2013, 03:53 PM   #104
cormier
cormier's Avatar
I have one of those tii reservoirs if you need it. Ya mounting is a pain. I used an ix brake res that has a clutch fluid bung off it. Congrats on gettin this far dude!
Old 08-27-2013, 07:40 PM   #105
Woofer
Woofer's Avatar
Thanks man. I figured it was gravity fed. I did a little searching on google and found some info tht helped me out.
I ended up using a 540 remote res. I had to cut the lower part of the res into a half moon shape. Which happen to sit perfectly on one of te groves that the brake booster had. I left enough material on the res so I could drill a hole and use a nut and bolt to secure it to a bracket that comes up from the master cylinder bolts and curves nicely over the brake booster right to the grove where the res sits.
Ill post up some pics when I get a chance.
