09-11-2011, 10:50 AM
#1
Car: e36 328is S/C'd
Just added an e30 to my collection!
Ok so! i needed a winter car since im building my enigne in my e36, and i found a 325i i think, its a convertible, its auto  and its got 280km comes with are hard top and brand new tires, its been repainted to matte black... no rust and underneath is pretty clean  there isnt a soft top inside.... but i need a few things for the interior, like door cars and alot of stock trim pieces... the car hasnt been run for the last 3 years!!!! what kinda changes should i do! i know i should do a tune up for sure!
The front bottom half of the bumper is missing and one of the stock projectors housings need to be replaced....
the gear selector is broken :S unno how but its the first time i ever seen it snap
it starts fine but one spark plug wire does need to be replaces... any one know if i have to buy the whole spark plug wire from the stealership????
Next issue is that the clutch fan just started to rub against my rad hose!!!!
Can i do a FDM on it
The Engine is ticking pretty loud...... im going to put some locus oil addictive and see if it runs a bit better.... keep in mind it hasnt been run for 3 years....
So what do u guys think... i mean there probably will be a few more problems latter but right now its pretty.
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
09-12-2011, 09:22 AM
#2
Car: e30 with e91 beater
I think you need to:
change the timing belt / water pump
change the oil
change the coolant
adjust the valves
flush the brake fluid
check all other fluid levels (trans, diff)
examine engine mount bushings (fan rubbing rad hose = engine mounts)
don't add lucas additive
fix all broken things
post pics
The first four things aren't things you can skip. You must do them before driving the car.
09-12-2011, 09:31 AM
#3
12 Years with the E30
Car: 325i 1987
If you know one wire is shot you can replace the one wire. I kept the longest good wire from another car and have it in my long distance travel kit.
if you're doing the belt you'll want to do the tensioner as well.
09-12-2011, 09:38 AM
#4
Thanks, forgot the tensioner in the list.
I got aftermarket wires (Kingston brand) from ebay, Canadian seller a few years ago and was very happy, but you can usually find a wire from someone with an incomplete set if you ask around.
09-12-2011, 09:51 AM
#5
Car: 325IS 87-325IC 89-IC
I agree, do the timing belt/tensioner/waterpump combo. then tune up which would include changing the valve cover gasket and adjusting the rockers..noisy means you need to adjust them. Don't be to alarmed if you gotta spend a grand on it up front. if it's a winter beater; don't get carried away..lol
#6
Car: Many
LOL...man alive, I went through a coolant hose at mosport before checking that.
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
09-14-2011, 08:12 PM
#7
Damn... i was hoping this is will just a cheap winter beater since i dont want to take my e36 out.... hmmm i think the waterpump is good, the coolant is clean. i know i need an oil change and a vavle adjustment asap.... the engine mounts going to take so much of my time.. and its got like 280,000km on it i was thinking maybe lucas would help... jsut 10% of the bottle mixed in with 10 w 30.....
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
09-14-2011, 08:24 PM
#8
500 to get it licenced, etested..... and like 800 for parts..... mine as well drive the e36 and just take the supercharger out  .... hmmm this is a tough decision
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
09-15-2011, 12:47 PM
#9
It sounds like you haven't done the etest yet.. I'd start with that. If you can't get it to pass etest then you're ****ed anyway.
Then, bare minimum (cheap beater method) = change the timing belt and tensioner, adjust valves (reuse the gasket, use RTV if it tears), change the oil. Engine mounts are very cheap and easy to change. Perhaps replace that hose if its chewed up.
You really do have to change the timing belt. If its old, and especially if it's sat unused, you run a high risk of it snapping and then you have 0.
Even at $1300.. what would you expect to pay to get a road worthy car?
09-15-2011, 01:10 PM
#10
Car: S54
&%$#ing awesome.
09-15-2011, 01:17 PM
#11
Unless this is some inside joke.. you can't "tell" if your waterpump needs replacing by the cleanliness of coolant. You can't tell it needs replacing by any means other than:
a. it's broken
b. it's due to be change, which on the m20 is always done when you do the timing belt
If the water pump goes, you'll have to redo the timing belt to do the water pump because the pump and tensioner share a bolt.
09-15-2011, 01:49 PM
#12
Car: 325i 1987
Everlast is right about coolant condition.
Rotate the water pump by hand when it's all apart, should rotate nice. Shouldn't have bearing play, flat spots, or excessive noise.
Usually it's just the gasket that has failed.
I have changed the water pump without the belt. The tensioner spring just adjusts the pre-load on the belt before tightening, once tightened it shouldn't move so it shouldn't need the spring until the next time the belt is replaced. But yes proper procedure dictates keeping the spring/pin in there.
09-15-2011, 01:57 PM
#13
Personally if the water pump didn't have too many miles, I would skip it, but I wouldn't skip the timing belt.
09-15-2011, 03:50 PM
#14
a. it's broken
lol sorry i ment that the water pump was changed by th PO and the cooling system looks fine, the rads 2 years old and havent been used much, he starts the car every week or so.... and the coolant must have been flushed cuz its clean.
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
09-15-2011, 03:53 PM
#15
Make up your mind.
In any case, a water pump failure is just a break down. The timing belt is what you should be discussing. It's failure = end of the motor.
