Old 09-10-2011, 02:33 PM   #1
blue dragon
duh!
FS: 10 mm Rogue Engineering spacer - 2 piece
With a normal 10mm spacer, there isn't enough lip to support the centre bore of a wheel in a hubcentric design. RE fixed this by designing a 2 piece spacer. Centre bore is 72.5mm
The small piece extends your hub so that the wheels remain hub centric and the hub carries the load, not the wheel lugs. The edges are chamfered, so you can pry them off without getting them stuck to the hub.
I can't use these anymore since the X5 ix 74.1 centre bore. These will fit E46 with the exception of the E46 Xi I think. Price is $80 and includes the longer bolts. PM me or email me wiward(at)rogers.com if interested. They are a little bit dirty, but I know you guys can clean them up :p
They fit like this
[/quote]
blue dragon is offline   Reply With Quote
Old 09-11-2011, 08:10 AM   #2
Quickid
Will the hub extender work on the rear hubs?
I need something like this for the rear but all hub extenders I see on the web says it's designed for the front only.
Quickid is online now   Reply With Quote
Old 09-11-2011, 09:25 AM   #3
blue dragon
duh!
I think this is for the front only, but you are welcome to try it. You can stop by my place and try it to see if it fits.
Old 01-04-2012, 08:17 PM   #4
Stirlitz
Stirlitz's Avatar
Are they still available?
Stirlitz is offline   Reply With Quote
Old 01-05-2012, 04:17 PM   #5
blue dragon
duh!
These were sold awhile back
