Old 07-05-2008, 08:11 PM   #1
Pinto009
how do you remove the rear springs from an e36
how to remove rear springs for e36 do i have to remove the lsd 1998 m3
Pinto009 is offline   Reply With Quote
Old 07-05-2008, 08:50 PM   #2
Spoose
are you changing shocks, or just removing springs? just undo the bolt that holds the bottom of the shock, the spring should just come right out. may need to apply some leverage downward to the arm, but it should come right out.
Current Rides: 964 C2
Past Rides: 94 318is, 97 M3, 01 C2 Cab, 02 330ci, 06 323i, 05 330cic M Sport, 02 M3
Spoose is offline   Reply With Quote
Old 07-05-2008, 09:14 PM   #3
^^^Yes, thats right, it should just come off with just a pry bar...If its too tight, you can spray some WD40 on it, makes the job easyer.
Old 07-06-2008, 11:06 PM   #4
Bmwstylz
Bmwstylz's Avatar
and to put it back on - reverse of disassembly or.. do you need spring compression tool?
"Get rich or die tryin!"
Bmwstylz is offline   Reply With Quote
Old 07-06-2008, 11:36 PM   #5
Install is a bit harder, unless you got lowering springs (wich is the case many times, so thats easy), but for stock springs, its best to lift the car from both sides, otherwise the sway bar puts pressure on one wheel...so it cant drop low enaught...
Old 07-07-2008, 04:53 PM   #6
Pinto009
thnaks guy just did them thanks for all the help i taught it was done like that but on any other forums they said you needed to lower the lsd but it did not make sense thanks again
Old 07-09-2008, 03:24 PM   #7
Big T
94 318is
They say you need to lower the diff or disconnect the drive axles because you acn damage the universal joint on the cv axles by prying on them too hard to remove the spring, but who cares.
Big T is offline   Reply With Quote
Old 09-16-2011, 10:22 AM   #8
The Question
What is said here about lowering springs, does that apply to a non M car installing OEM M3 springs? I imagine the M3 springs are lower, so they install like a lowering spring and would lower a non M E36 a bit?
The Question is offline   Reply With Quote
Old 09-16-2011, 11:13 AM   #9
^^basically what Fil is saying is lets say a stock spring is 6 inches uncompressed, and there's 5 inches clearance to fit it in, you'll have to compress it 1 inch.
Since most lowering springs are shorter than stock springs (lets say 4.5 inches) you dont have to compress them at all to re-install.
Make sure you check everything is lined up after you lower the car.
