Old 09-06-2011, 08:40 PM   #16
Originally Posted by bimmerpimp View Post
if you actually CUT out and replace the entire rust area with new metal, it'll never come back
When you cut and weld, in most cases the inside is not painted or fully protected, so yes it will and it does! Unless you are doing a "down to the shell" restoration...
Old 09-06-2011, 08:47 PM   #17
Originally Posted by noodles101 View Post
^ not if u do it properly.....
And to do bodywork properly costs A LOT of $$$...And that brings us back to square one, better get something solid then fighting cancer, unless you want a beater...IMO
Old 09-06-2011, 09:01 PM   #18
bimmerpimp
Im a BBing Bimmer Owner
bimmerpimp's Avatar
not always no, if you do it right, you prime/paint immediately after you do your initial cut, then you weld your piece in then you again prime/paint.....once you have your rust completely cut out and replaced with new metal. Its virtually as new.
It is rather very inexpensive to do, even on your own...
bimmerpimp is offline   Reply With Quote
Old 09-07-2011, 08:10 AM   #19
vintagez
I would want the car certified and e-tested if I was buying it, either one could cost a bit if it needs anything, the first car at that price is the better deal, but it should come certified, what is he hiding?
vintagez is offline   Reply With Quote
Old 09-09-2011, 02:00 PM   #20
Dinher
I'd go with the cheaper one. Km doesn't matter as much if the maint was kept up to date. Low km could be bad in the sense that it's always at the shop and no mileage was put on it.
Dinher is offline   Reply With Quote
