Old 09-17-2011, 12:23 PM   #16
jabela
Originally Posted by vic325ci View Post
I have bridgestone potenza's, uh 245x35x18's I believe, as for the rusted hangers that jabela mentioned, it could be that, but it doesnt explain the loss of power when I hit the gas. I probably should have made it more clear that when I hit the gas and it hits that sweet spot in the rpm's, I might as well be in reverse cause the car doesnt reallly accelerate at all...
Automatic transmission or manual? Could be a slipping clutch or faulty auto. Could be damaged guibo, could be bad transmission mounts.
www.maisonapothecare.ca
Old 09-17-2011, 03:31 PM   #17
vic325ci
vic325ci's Avatar
its manual, the clutch has about 40k on it, I'm 110 percent sure its not the tranny, its gotta be the rear end...I put my car up on jacks earlier today, took the wheels off and then the rotors, everything was ok, nothing was seized or anything so its gotta be the diff or driveshaft...
vic325ci is offline   Reply With Quote
Old 09-18-2011, 01:01 AM   #18
jabela
Did you try putting it in gear while it was on the jacks? You might be able to hear/see something.
Old 09-19-2011, 09:45 AM   #19
AlphasquadM3
hey vic, did you get my pm?
AlphasquadM3 is offline   Reply With Quote
Old 09-19-2011, 09:50 AM   #20
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
If it's related to power delivery it could be the clutch or the diff.
Old 09-19-2011, 01:12 PM   #21
vic325ci
vic325ci's Avatar
yea got your pm, I'm still gonna take it into bmw just to have them check it out, once they figure out what it is, i'll figure out where to go. Thanks for the pm, whats your address? I live in Brampton, im not too good with non region of peel shops lol
Old 09-19-2011, 01:34 PM   #22
jabela
If you're gonna take it somewhere, I would recommend RMP Motors instead of the stealership. It will be cheaper and Rocco will do a better job.
