Old 08-21-2011, 08:31 PM   #1
tuee
Help installing rear window trim
Hey guys, I'm currently in the process of putting my e30 back together. I'm having a bit of trouble installing the rear window trim piece. I've tried lubing it up but no go either. Any help would be appreciated, thanks.
Its this piece below
tuee is offline   Reply With Quote
Old 08-21-2011, 09:49 PM   #2
Ceeker
are you speaking of the piece which sits just behind the window trim? looks kinda like a boomerang? if so, that piece should just pop in place. You gotta give it a good nudge. Also make sure the clips aren't deformed otherwise you'll be having some trouble.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 08-21-2011, 11:02 PM   #3
tuee
Nope, its the outer trim thats just rest there. I believe the lip inside the piece needs to slip inside the rubber.
[img]http://realoem.com/bmw/diagrams/v/k/2.png[img]
its 6, 12, 21...its all attached together, do I need to separate them?
[img]http://i39.tinypic.com/314osw5.gif[img]
g, i, h, but on a coupe
thanks
