Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 02-21-2012, 03:25 AM   #106
e30_kid89
The Afro-stig
e30_kid89's Avatar
VDO vision series ftw. Blends in like stockshizzle
Old 02-21-2012, 11:34 AM   #107
cormier
cormier's Avatar
Wow I do really like them-- pros being they're wayyy more cost effective than the stack ones, and look great
Cons -- the 90 degree sweep vs full 270 with the stacks.
Are they good quality too?
Old 02-21-2012, 06:22 PM   #108
cormier
cormier's Avatar
VDO vision vs. STACK
Old 02-21-2012, 07:30 PM   #109
BigD
the misanthropist
BigD's Avatar
I wouldn't worry about the sweep angle. You won't be looking for precise numbers anyway, just memorize the "perfect" and "uh oh" needle angles.
Old 02-25-2012, 01:50 PM   #110
cormier
cormier's Avatar
In other I-screwed-up news, dropped my tranny mount on the floor and now it looks like this. Can't remember if it was straight before
Drilled out my e30 brace and mounted them up to find that the tabs restrict the mount! I'll have to bend or grind them down I guess to get it to sit flush
Gauge-wise, think I'm going to go with the VDO vision ones. They look awesome and wont break the bank.
I need to get back out to the car and find out what thread size the TB heater flange is in the head, I want to use that for water temp--couldn't find it online.
Old 02-25-2012, 05:40 PM   #111
Woofer
Woofer's Avatar
Nice work with the engine bay. I'm glad you decided to go through with it. Skipping that step could have haunted you lol. Keep it stock color. I have crazy OCD tendencies like your self.
How much lengthening of the harness did you have to do to tuck it?
Keep up the good work.
Old 02-25-2012, 06:21 PM   #112
cormier
cormier's Avatar
Thanks! I know it would have haunted me, I'm glad I decided on it too.
The wires aren't lengthened yet, I wanted to wait until after the paint so that they can be bagged easily at the shop.
I don't think that the length of the wires will be too much of an issue, maybe a few inches is all thats needed. There's a hole under the fusebox that will easily hold all the wires, but the connectors won't fit through it. This is the main reason that I'm going to lengthen them. I can fit all the wires exactly through where I want with no difficulty and keep it clean without drilling bigger holes. The thing I need to take a look at is where to come back into the bay near the drivers headlights. I will have to mock up the fenders when I do it and check out spacing.
I couldn't find any good pictures of where people have come back up, but theres enough small spaces that it shouldn't be an issue.
Old 03-03-2012, 07:26 PM   #113
cormier
cormier's Avatar
Today is pissin me off.
My drivers side motor mount won't fit. The bottom right hole wont line up-- think ill widen the hole on the mount a bit to get it. You can't be supposed to run 3 bolts lol
It's the bolt that looks offset
Also, my oil centre isn't 1/8 NPT. The fitting I bought to test is too small. The coolant bung for the TB heater also isn't 1/8. Piss off on both counts. I was hoping for 3/3.
All 3 holes
I can't find the bolts for the alternator mounting. I don't know which diagram I haven't checked yet.
To make matters worse, the powers been out here for over 6 hours now due to an accident on 24. This means no light, heat, drills or compressors.
Old 03-03-2012, 07:49 PM   #114
El Gato Liso
El Gato Liso's Avatar
the mounts will fit! i remember specifically that problem; those holes wont line up.
you dont need to widen anything! lemme dig through my swap pics...
R.I.P. E30
Old 03-03-2012, 07:58 PM   #115
El Gato Liso
take a pic with the mounting arm on the block.
R.I.P. E30
Old 03-03-2012, 08:34 PM   #116
I haven't looked closely at the motor mounts, any chance that the bolt pattern is A-symmetrical so that you don't accidentally put the right side motor mount on the left side or vice versa?
Old 03-03-2012, 08:41 PM   #117
El Gato Liso
they're distinctly differentiable. one mount looks like its upside down *pass side*, the driver mount side
the right mount it the driver side. if you look at the bottom right hole, it oval shaped to fit that offset hole on the driver side of the block.
it will fit! because you have to make it fit.
R.I.P. E30
Old 03-03-2012, 10:03 PM   #118
cormier
cormier's Avatar
Ya no chance I mixed them up-- theyre pretty clear with the way the motor sits tilted
I'll take a pic in a bit -- still no power here playin monopoly with the kids lol.
No way to bend it and make it fit, for sure either the block needs to be re tapped or the mount arm needs drilling :s
Old 03-03-2012, 10:29 PM   #119
cormier
cormier's Avatar
Pix of the motor mount arm
I know it doesn't seem like a lot, but there's no way to get that bolt in, the mount has no play when the other bolts are in
Old 03-03-2012, 10:52 PM   #120
Rob's motor mount has a slotted hole on the same hole your mount doesn't line up with. Looks like you need to slot that hole a bit.
Tags
build, dohc, e30, engine swap, s52
