Old 08-11-2011, 08:12 PM   #1
Denny
Gathering interest in a 1 Piece Driveshaft for the E30
Hi
Like the title says Im gathering interest in those that would want a 1 piece driveshaft for their E30. I found a place that will build me one for mine (M20B25 engine) since mine will be the guineepig it could benefit other in some sort of group buy that could be put together.
So please list your name if you are interested. right now its just people interested more info will come...
1.Denny Medeiros
2.
3.
4.
5.
6.
7.
8.
9.
10.
etc...
Denny
___________
2003 BMW 330i M-sport AA SC 5-speed -SOLD
2006 BMW 330i 6-speed black SOLD
2001 BMW X5 4.4 - Auto - black on black - SOLD
1989 BMW 535i - 5-speed - black -SOLD (kept M30B35/tranny for E30)
1985 BMW 325 E 5-speed (new project)
1987 BMW 325 5-speed - work in progress
http://bmw325e30.blogspot.com/
Part 2 (Supercharger/turbo build)
http://bmw325e30turbo.blogspot.com
Other interests:
http://www.xbox360.com
http://bodyspace.bodybuilding.com/dennymedeiros
Denny is offline   Reply With Quote
Old 08-11-2011, 10:12 PM   #2
Ceeker
Question: reason for going with the one piece?
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
1 90 325is white - keepin
1 87 325i vert -red - keepin
Old 08-11-2011, 10:49 PM   #3
Denny
Here is a few BIG reasons
1) Strength of 1 piece design (especially with forced induction)
2) no more center bearings and bmw hardware that is not serviceable less things to fail
3) 1 time balance (at time of build) so no more expensive balancing
4) ease of removal and install
and I found the right guy to do it
Denny
___________
Other interests:
Old 08-11-2011, 11:18 PM   #4
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Will there still be a U-joint on the shaft at both ends, or just a solid shaft end to end? Cause it better have at least one U joint.
1986 E30 325e (killed)
1986 E30 325es (died)
1988 E30 325i (rotted)
1992 E34 525i (sold)
1992 E30 318i (cabrio, Dad's)
1989 E30 325i (Mom's)
1991 E30 318i (cabrio, summer car)
1991 E30 318is (Winter car)
1992 Euro M5 (driveway decoration)
1994 E36 325is (driveway junk)
Old 08-11-2011, 11:23 PM   #5
Denny
Not sure on the technical aspect of the construction. The construction will be based on strength, ease of install and removal and without using expensive rare to find parts.
Denny
___________
Other interests:
Old 08-12-2011, 12:14 AM   #6
El Gato Liso
El Gato Liso's Avatar
i kinda like the fact that i can seperate my drive shaft on command. and when it comes to fitment being able to adjust the length of the shaft is a woowoo win
***E30 part out to come. Gimme a PM for any inquiries!***
Old 08-12-2011, 12:47 AM   #7
E30M42cab
E30M42cab's Avatar
Well, if it doesn't have at least one u-joint, you better be prepared for the guibo to tear up pretty quickly, as it will be the only thing compensating for and difference in the tranny angle and input at the diff. Better research this or you'll cause more problems than you solve. If you're not concerned on how it's built, I'd be happy to build you anything you ask for. Also, what price were you quoted for a single unit?
Old 08-12-2011, 12:57 AM   #8
E30M42cab
E30M42cab's Avatar
http://www.driveshaftshop.com/import...oly-driveshaft
Unless you're swapping some huge engine in and drag racing, you don't need this. How often do you ever have to replace the centre bearing and guibo if your car is just a DD? If you've done it once, you probably won't have to do it again, so why spend money on a driveshaft of all things? For your Turbo you say? How many turbo guys already run them?
Old 08-12-2011, 01:15 AM   #9
Eurostyle
Eurostyle's Avatar
+1! I've seen some cars snap the end of the transmission with the 1 piece design...NO enaugh flex at all...So many high HP BMW's this type, nothing wrong with it!
Eurostyle is online now   Reply With Quote
Old 08-12-2011, 07:53 AM   #10
Ceeker
This is the reason why I asked....BMW designed this shaft for a reason in this way. why try to re-engineer?
2 325i 4 dr - sold
Old 08-12-2011, 08:11 AM   #11
InfiniteDice
12 Years with the E30
InfiniteDice's Avatar
The only thing about the Stock shaft is you can't service the joints easily. If that mod could be made then I'd be interested.
Old 08-13-2011, 08:35 AM   #12
DR.ZED
I know that the two piece design actually moves in and out in the middle where it connects to take up the movement of the rear subframe. Essentially the driveshaft changes length ever so slightly.
In a single piece driveshaft the forward section slides on the input shaft of the transmission and a "transmission output shaft seal" holds the oil in while this happens.
If we do a one piece design what is going to take up the slack? I see the rubber guibo pulling apart, defeating completely the reliability especially if you're putting more torque to it.
How has this been addressed?
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 08-13-2011, 11:29 AM   #13
simplycars
simplycars's Avatar
one piece driveshaft is easier to manufacture so company like BMW would be using it for a long time to lower production costs. i wouldn't even consider it.
simplycars is offline   Reply With Quote
Old 08-13-2011, 11:56 AM   #14
Ceeker
I like the fact that domestic manufacturers didn't put grease nipples in the factory u-joints but one can easily replace those with joints that one can grease. there should be ones available for bmw's as well no?
2 325i 4 dr - sold
Old 08-13-2011, 09:37 PM   #15
DIY
Permanently Dirty
DIY's Avatar
I love the idea of making things better but, in all honestly after changing my gas tank and goin through the whole system this is the last thing I would try and redesign,....
Have you..
Reinforced the frame?
Installed them DTM replica suspension arms?
Upped engine power
Run slick tires?
Remapped the engine with electronic ignition?
Too many other places Žo spend money
Sorry bro
