Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 08-10-2011, 10:10 PM   #1
blakneto
blakneto's Avatar
Power Steering - ATF or Steering Fluid?
Just wondering if anyone uses ATF (ie Redline D4 ATF) or actual steering fluid??
Reading alot of posts that say you should only use D4 ATF in an e46?
Anyone have any personal experience???
Thanks in advance.
Old 08-10-2011, 11:01 PM   #2
ATF only in all BMWs.
It says so on the cap, and in your manual. RTFM
Old 08-10-2011, 11:20 PM   #3
blakneto
blakneto's Avatar
DOH!
Yah I deserve that...
Thanks!
Old 08-10-2011, 11:30 PM   #4
SickFinga
SickFinga's Avatar
This is incorrect btw. Cars with self leveling suspension use CHF11, but yeah in E46 case, ATF
Old 08-11-2011, 07:51 AM   #5
vintagez
make sure it is Dex III and not Dex VI
vintagez is offline   Reply With Quote
Old 08-11-2011, 10:18 AM   #6
ATF only in most BMWs.
ok fixed.
Old 08-11-2011, 10:34 AM   #7
Gamite
Gamite's Avatar
Sickfinga is here to point out all your mistakes.
www.gamite.net
Old 08-11-2011, 10:24 PM   #8
blakneto
blakneto's Avatar
Thanks Lads!
Used Royal Purple and a Turkey Baster and POOF, clean nice fluid!
RTFM and didn't find it in there... but its on the cap!
Thanks for the support!
Old 08-12-2011, 04:54 AM   #9
328iInt.o
I wouldn't go to fancy with all this synthetic nonesense.
I used to use Mobil1 ATF synthetic and in cold winter days, my steering was very difficult to turn for the first 10min - as if there was no power steering.
Switched it out to regular castrol atf dexron III and volia! No more tight cold steering.
Sometimes, the car just needs what it had from factory. None of this fancy redline royal purple stuff.
328iInt.o is offline   Reply With Quote
Old 08-12-2011, 03:00 PM   #10
blakneto
blakneto's Avatar
how cold is it where you are? :p
http://www.mobiloil.com/USA-English/...hetic_ATF.aspx
So far so good with the Royal Purple!
Thanks for all the replies!
Old 08-17-2011, 12:41 PM   #11
vintagez
I believe the other benefit ( and most desired ) is the better performance of synthetics at high temperatures as well as low, in the end its your car and your pump, whatever you want to use.
Old 08-18-2011, 04:59 AM   #12
328iInt.o
Well our cars were made the way they were for a reason, synthetic oil for example, or our light weight manual transmission fluid.
If our cars needed synthetic power steering fluid, they would have came that way. They have hundreds of engineers employed at BMW and our cars were made at premium hence our premium msrp. Maybe they thought there weren't any real advantages at cold/warm over synthetic? Or our pump handles non-synthetic better?
