Old 08-10-2011, 12:02 PM   #1
Gtfour
Gtfour's Avatar
FS: BMW E46 M3 2002 track car
Here is my BMW E46 M3 2002 for sale
I’m the second owner and had the car since 2007. Car now has 175000km. The engine has been changed last year. Every components of the brakes and suspension have been upgraded. Car don’t have any rust even if I drove it for 2 winters. Never been into any kind of accident, clean title, no off-road/track. It’s in perfect shape. There is stone chips and some dings but the original paint is still in really good shape.
Engine : 90000km
Clutch & flywheel :30000km
Looking for an E92 M3 or 997 GT3
Price : $35000 firm
marc_bujold09 at hotmail dot com
Pictures & build-up thread:
http://www.m3forum.net/m3forum/showthread.php?t=316864
http://www.maxbimmer.com/forums/showthread.php?t=139479
Lap time this year:
Tremblant 1:47-1:48
Calabogie 2:18
ASE 56.4
Corner balancing : 50/50 cross weight, car weight 2820lbs without driver and fuel
Exterior
-Vorsteiner VRS vented race carbon fiber hood
-Sunroof glass replaced with carbon fiber insert
-Gutted trunk
-APR GTC-300 carbon fiber wing with custom mount bracket
-SPA GT/LeMans mirrors
-Rear bumper vents
-front fenders vents
-Matte black kidney grill & side grill
-Smoked turn signal lights
-Smoked side marker lights
-Custom BMW emblem
-AeroCatch racing hood fasteners
-Lexan rear windows
-Alumalite front splitter / undertray panel
-Bimmerworld CF canards / Front dive planes
Interior
-10 points roll cage with rear subframe attachment points, full gussets, X Brace doors bar, head protection, ...
-SFI padding on roll cage
-Recaro Pole Position black velour seat / aluminium side mount / custom floor mount
-OMP Corsica Superleggero 350mm suede steering wheel
- MOMO steering wheel hub adapter
-Lifeline quick release
-OMP 1010 pedals
-OMP Formula 6point harness
-Jaffster shiftknob (long)
-Carbon fiber trims
-Wink multi-panel mirror (5)
-BMW radio blank plate
-Braille battery (11lbs)
-Blind Apex lap timer with transmitter/battery
Handling
-Moton Clubsport 2-way, coilovers rears
-Hyperco springs (900 front/500rear)
-Hyperco helper springs
-Ground Control racing front swaybars
-Ground Control adjustable swaybar end links
-Moton rear shock mounts
-Ground Control camber/caster plates
-Ground Control front control arms bushings
-Turner Motorsport adjustable rear camber arms
-Turner Motorsport front subframe reinforcement kit
-Turner Motorsport front strut tower reinforcement plates
-Turner Motorsport rear subframe reinforcement kit
-Turner Motorsport rear strut tower reinforcement kit
-BMW oem front strut brace
-BWsport 12mm spacers
-Turner Motorsport 75mm studs kit
-BMW Motorsport front control arms
-Ground Control adjustable tie rods
Braking
-Stoptech ST-40 4 pistons big brakes kit
-AeroRotors slotted 355mmx32mm floating discs
-Performance Friction PF01 race pads
-Stoptech stainless steel brakes lines
-Turner Motorsport carbon fiber brake backing plates
-Bimmerworld carbon fiber brake ducts
-3” brake duct hoses
Engine
-Shark injector race version performance software
-Turner Motorsport / Fluidyne oil cooler kit
-BMW Motorsport thermostat 55degrees
-Custom 3" exhaust line
-Catless stainless steel headers
-Evosport underdrive pulleys
-K&N cold air intake system
-Group N motor mounts
-Bimmerworld brass radiator bleeder screw
-Bimmerworld S54 EGR delete block-off plates
-Bimmerworld S54 Magnetic oil drain plug
-Bimmerworld Oil cooler diverter valve
-Spal 16” pusher type fan, straight blades
-Bimmerworld water pump shaft nut
-Custom stainless steel clutch stop
-Gulf 10w60
Wheels & Tires
-SSR Type C 18’’x9.5’’ et35
-TR MT1 18"x9.5" et35 18"x10" et25
-Pirelli slicks 265/645r18
-Hoosier R6 275/35r18
Transmission/drivetrain
-UUC Short Shift Kit - Evo 3 with dual shear selector rod
-BMW Motorsport custom built 4.10 pinion/ring differential
-BMW Motorsport transmission mounts
-Redline D4 ATF
-Powerflex differential mounts
-Redline 75w140
Gtfour is offline   Reply With Quote
Old 11-08-2011, 12:41 PM   #2
Gtfour
Gtfour's Avatar
**New price 30000$**
Old 12-17-2011, 08:41 PM   #3
Gtfour
Gtfour's Avatar
Sold the car today
